BT.com
Wishlist
Kyocera FS-9130DN Mono Laser Printer
Kyocera FS-9130DN Mono Laser...
£2,121.45
£2,121.45
Add to wishlist
Delivery
Standard Due date unavailable
With a print speed of 40 pages per minute in A4, the Kyocera FS-9130DN is ready to carry you through the heaviest of loads without slowing down. Fast, efficient and reliable, this printer also has a highly functional modular design. The paper and finishing options make it easy to fit the printer to your department's precise needs.
Kyocera FS-9130DN - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
68 kg
Media Size Class
A3/Ledger
Max Media Size
A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm)
Max Media Size (Custom)
297 mm x 450 mm
Print Speed
Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 23 ppm - B/W - A3 (297 x 420 mm) , Up to 33 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 16 ppm - B/W duplex - A3 (297 x 420 mm)
Max Resolution (B&W)
1800 x 600 dpi
Image Enhancement Technology
Kyocera Image Refinement 2
Automatic Duplexing
Parallel, USB, LAN, USB host
PowerPC 750FL 600 MHz
RAM Installed (Max)
64 MB ( 576 MB ) - DDR SDRAM - DIMM 100-PIN
Card Reader
Language Simulation
PostScript 3, PCL 6, EPSON LQ, Diablo 630, KPDL3, KC-GL, PDF, PRESCRIBE IIe, IBM ProPrinter X24e
Barcodes
PDF417
Media Type
Labels, plain paper, foil paper, recycled paper
Total Media Capacity
1200 sheets
Media Handling
2x 500-sheet input trays, 200-sheet multipurpose tray
Monthly Duty Cycle (max)
180000 pages
Recommended Monthly Volume
20000 pages
Print server - Ethernet, Fast Ethernet
AC 230V
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.2 or later, Apple MacOS 9.x or later
Microsoft Certification
Certified for Windows Vista
( France - 1 year )
59.9 cm x 64.6 cm x 61.5 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1800 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
3.5 sec
Language Simulation
Fonts Included
136 x PostScript 3 , 80 x PCL , 1 x bitmapped , 45 x barcode
Barcodes
PDF417
Media Handling
RAM
RAM Installed (Max)
64 MB / 576 MB (max)
Technology / Form Factor
Slots Qty
1
Empty Slots
1
Card Reader
Card reader
Supported Flash Memory Cards
CompactFlash Card
Media Handling
Media Type
Media Size Class
A3/Ledger
Max Media Size
297 mm x 450 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm), 297 x 450 mm, 88 x 148 mm
Media Weight
45 g/m² - 200 g/m²
1200 sheets
Media Feeders
1 x automatic - 200 sheets - 297 x 450 mm weight: 45 g/m² - 200 g/m² , 2 x automatic - 500 sheets - 297 x 432 mm weight: 60 g/m² - 105 g/m²
Max Media Capacity
4200 sheets
Output Trays Capacity
500 sheets
Duty Cycle
180000 pages
20000 pages
Print server
Expansion Bays
1 (total) / 1 (free) x internal
Expansion Slots
1 x CompactFlash Card
1 x LAN - RJ-45 , 1 x parallel - 36 PIN Centronics , 1 x USB 2.0 - 4 PIN USB Type B
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
TUV, ISO 9001, GS, ISO 14001
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
710 Watt
Power Consumption Stand by / Sleep
160 Watt
Environmental Standards
ENERGY STAR
( France - 1 year )
Sound Emission (Idle)
37 dBA
Sound Emission (Operating)
56 dBA
59.9 cm
64.6 cm
61.5 cm
68 kg
Accessories
Kyocera Toner Kit TK-710
Quicklinx: 4CFG | In Stock
£151.33
Scroll to top
