BT.com
Wishlist
Kyocera FS-6525MFP A3 Mono Laser Multifunction Printer
Kyocera FS-6525MFP A3 Mono Laser...
£1,684.30
Hurry, only 2 left in stock!
£1,684.30
Add to wishlist
Delivery
Standard 1-3 working days
This multifunctional device offers all the benefits of a professional document management solution for workgroups and small offices. Cost-efficient and Eco-friendly offices will appreciate Kyocera's unique ECOSYS technology which increases operating life, reduces environmental impact, cuts printing costs and ensures reliability.
Kyocera FS-6525MFP - multifunction printer (B/W)
Printer / copier / scanner
Copier Type
Digital
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 25 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 25 ppm
Max Printing Resolution
Up to 600 x 600 dpi
Scanning
600 dpi
Original Size
140 x 182 mm (min) - A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
98 x 148 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
600 sheets
Max Media Capacity
1600 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
300 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to network
AC 230 V (50/60Hz)
59 cm x 59 cm x 69.4 cm
52.2 kg
Environmental Standards
ENERGY STAR Qualified
2 years warranty (France - 1 year)
Copier Type
Digital
Printing Technology
Laser - monochrome
PC Connection
Standard Memory
1 GB
Max Supported Memory
2 GB
Supported Flash Memory
CompactFlash
Copying
Max Copying Speed
Up to 25 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
2 on 1, 4 on 1
Printing
Up to 600 x 600 dpi
Max Printing Speed
Up to 25 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, KPDL3, PDF, XPS
Automatic Duplexing
First Print Out Time B/W
8 sec
Scanning
Automatic Duplexing
Optical Resolution
600 dpi
Grayscale Depth
8-bit
Document & Media Handling
Min Original Size
140 x 182 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
98 x 148 mm
Max Media Size
A3/Ledger
Min Media Weight
45 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), 297 x 432 mm, 140 x 182 mm, 98 x 148 mm
600 sheets
Max Media Capacity
1600 sheets
100 sheets
300 sheets
Input tray - 500 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 98 x 148 mm - A3/Ledger (297 x 432 mm) weight: 45 g/m² - 256 g/m² , ADF - 50 sheets size: 140 x 182 mm - A3/Ledger (297 x 432 mm) weight: 45 g/m² - 160 g/m² , Output tray - 250 sheets , Job separator tray - 50 sheets
Speed Details
Printing: up to 25 ppm (A4) - B/W , Printing: up to 12 ppm (A3) - B/W , Copying: up to 25 ppm (A4) - B/W , Copying: up to 12 ppm (A3) - B/W , Scanning: up to 40 ipm (A4) - B/W , Scanning: up to 20 ipm (A4) - colour
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Network Protocols
TCP/IP, IPX/SPX, AppleTalk, NetBEUI, HTTPS, IPv4, IPv6
Security Protocols & Features
Kerberos, SSL, IPsec, 802.1x
Operating System Support
UNIX, Linux, Apple MacOS X 10.4 or later, MS Windows
AC 230 V (50/60Hz)
530 Watt
Power Consumption Standby
114 Watt
Power Consumption Sleep
0.9 Watt
Warm-Up Time
20 sec
Consumables Included
1 x Cartridge (black) - up to 3000 pages
TUV, ISO 9001, GS, ISO 14001
ENERGY STAR Certified
59 cm
59 cm
69.4 cm
52.2 kg
Sound Emission
27.1 dBA (idle) / 46.8 dBA (operating)
Scroll to top
