BT.com
Wishlist
Kyocera FS-4200DN Mono Laser Printer
Delivery
Standard Due date unavailable
The office workhorse, this printer will run and run and run, printing up to 50 ppm and integrating perfectly into any network environment. The device has enhanced security features, flexible paper handling options with a maximum paper capacity of 2,600 sheets. Its long life components mean incredibly low running cost and impact on the environment.
Kyocera FS-4200DN - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
14.6 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 50 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
PowerPC 465 750 MHz
RAM Installed (Max)
256 MB (1280 MB)
Card Reader
Language Simulation
PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, PRESCRIBE IIe, XPS, EPSON LQ 850, IBM ProPrinter X24e, PDF 1.7
Barcodes
UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
Media Type
Plain paper
Total Media Capacity
600 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray
Monthly Duty Cycle (max)
250000 pages
Recommended Monthly Volume
30000 pages
Print server
Printer Features
Kyocera ECOSYS Technology
AC 230V
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.4 or later
38 cm x 41.6 cm x 32 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
9 sec
Language Simulation
Fonts Included
93 x scalable , 1 x bitmapped , 45 x barcode
Barcodes
Printer Features
Media Handling
PowerPC 465 750 MHz
RAM
RAM Installed (Max)
256 MB / 1280 MB (max)
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 140 x 210 mm
Media Weight
60 g/m² - 220 g/m²
600 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
Max Media Capacity
2600 sheets
Output Trays Capacity
500 sheets
Duty Cycle
250000 pages
30000 pages
Print server
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 10000 pages ISO/IEC 19752
TUV, ISO 9001, GS, ISO 14001, ISO 7779
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
677 Watt
Power Consumption Stand by
12.8 Watt
Environmental Standards
Blue Angel
ENERGY STAR
Sound Emission (Idle)
27.3 dBA
Sound Emission (Operating)
54.4 dBA
38 cm
41.6 cm
32 cm
14.6 kg
Scroll to top
