BT.com
Wishlist
Kyocera FS-3640MFP A4 Mono Multifunction Laser Printer
Delivery
Standard Due date unavailable
The FS-3640MFP is made for demanding work groups looking for compact and easy to use highly productive MFP. Simplified login eliminates access bottlenecks while keeping security high. The document workflow can be easily optimized with the customizable color touch panel and the integrated solution platform HyPAS. The long life components provide exceptional reliability and unbelievable low running costs, while keeping environmental impact at an absolute minimum. Perfect for your office!
Kyocera FS-3640MFP - multifunction printer (B/W)
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
200000 impressions
Recommended Monthly Volume
25000 pages
Max Copying Speed
Up to 40 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 40 ppm
Max Printing Resolution
Up to 1800 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Scanning
600 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
600 sheets
Max Media Capacity
2100 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, HyPAS (Hybrid Platform for Advanced Solutions)
AC 230 V (50/60Hz)
49.4 cm x 49.7 cm x 56.7 cm
26.4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
2 years warranty (Italy - 1 year)
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
200000 impressions
25000 pages
Display Features
Touch screen
PC Connection
Standard Memory
1 GB
Max Supported Memory
2 GB
Supported Flash Memory
CompactFlash
Copying
Max Copying Speed
Up to 40 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy
Printing
Max Printing Speed
Up to 40 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PDF, XPS, Diablo 630, EPSON LQ-850, IBM Proprinter X24E, Lineprinter
Automatic Duplexing
First Print Out Time B/W
11.5 sec
Scanning
Optical Resolution
600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Machine Features
One-Touch Dialing
100 station(s)
Broadcast Transmission
Delayed Transmission
Remote Fax Retrieval (Polling)
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), Oficio (216 x 343 mm)
600 sheets
Max Media Capacity
2100 sheets
100 sheets
500 sheets
Input tray - 500 sheets size: 105 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: 140 x 210 mm - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 500 sheets
Speed Details
Copying: up to 40 ppm (A4) - B/W , Printing: up to 40 ppm (A4) - B/W , Scanning: up to 35 ppm (A4) - B/W , Scanning: up to 25 ppm (A4) - colour
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Network Protocols
IPP, SNMP, IPv6
Security Protocols & Features
SSL, IPsec, 802.1x
Operating System Support
MS Windows XP, MS Windows 2000, UNIX, Apple Mac OS X, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2
AC 230 V (50/60Hz)
642 Watt
Power Consumption Standby
93 Watt
Power Consumption Sleep
15.4 Watt
Warm Up Time
22 sec
First Copy Out Time B/W
7 sec
Consumables Included
1 x Cartridge (black) - up to 7500 pages
Supported Windows 7 Features
Windows HD Imaging
TUV GS, ISO 9001, ISO 14001
ENERGY STAR Certified
Limited warranty - 2 years - carry-in
49.4 cm
49.7 cm
56.7 cm
26.4 kg
Sound Emission
32 dBA (idle) / 55 dBA (operating)
Scroll to top
