BT.com
Wishlist
Kyocera FS-2100D A4 Mono Laser Printer
Kyocera FS-2100D A4 Mono Laser...
Free delivery
£290.01
Free delivery
£290.01
Add to wishlist
Delivery
Standard Due date unavailable
The Kyocera FS-2100D can print at up to 40 pages per minute with a resolution of up to 1200dpi. Double sided printing is standard and 100 sheet multi-purpose tray and 500 sheet universal paper cassette are included. FS-2100D A4 mono laser printer also has a high capacity memory of 128MB of RAM to help it deal with complex print jobs that are sent to it. Printing direct from a USB stick is also included as standard with it's USB Port on the front of the Kyocera FS-2100D printer.
Kyocera FS-2100D - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
13.5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 40 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Automatic Duplexing
USB, USB host
PowerPC 465 500 MHz
RAM Installed (Max)
128 MB (1152 MB)
Card Reader
Language Simulation
PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, PRESCRIBE IIe, XPS, EPSON LQ 850, IBM ProPrinter X24e, PDF 1.7
Barcodes
UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
Media Type
Plain paper
Total Media Capacity
600 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray
Monthly Duty Cycle (max)
150000 pages
Printer Features
Kyocera ECOSYS Technology
AC 230V
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.4 or later
2 years warranty
38 cm x 41.6 cm x 28.5 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB, USB host
1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
9 sec
Language Simulation
Fonts Included
93 x scalable , 1 x bitmapped , 45 x barcode
Barcodes
Printer Features
Media Handling
PowerPC 465 500 MHz
RAM
RAM Installed (Max)
128 MB / 1152 MB (max)
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Media Weight
60 g/m² - 220 g/m²
600 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
Max Media Capacity
2600 sheets
Output Trays Capacity
250 sheets
Duty Cycle
150000 pages
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 2 x direct print port - 4 pin USB Type A
TUV, ISO 9001, GS, ISO 14001
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
564 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 2 years , Limited warranty - drum - 3 years or 300,000 pages
Sound Emission (Idle)
29.5 dBA
Sound Emission (Operating)
52.4 dBA
38 cm
41.6 cm
28.5 cm
13.5 kg
Scroll to top
