BT.com
Wishlist
Kyocera FS-1320MFP Mono Laser Multifunction Printer
Kyocera FS-1320MFP Mono Laser...
Free delivery
£124.62
Free delivery
Hurry, only 1 left in stock!
£124.62
Add to wishlist
Delivery
Standard 1-3 working days
The FS-1320MFP is designed for easy operation, low noise and compact size. It focus on essential functionalities, including print, copy, scan and fax capabilities as standard, which makes them ideally suited for personal, home office and small business users.
Kyocera FS-1320MFP - multifunction printer ( B/W )
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser ( monochrome )
Monthly Duty Cycle (max)
10000 impressions
Recommended Monthly Volume
1500 pages
Max Copying Speed
Up to 20 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 20 ppm
Max Printing Resolution
Up to 1800 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR
Scanning
600 x 600 dpi
Original Size
140 x 210 mm (min) - 216 x 356 mm (max)
Original Type
Sheets
Document Feeder Capacity
40 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
250 sheets
Output Trays Capacity
100 sheets
PC Connection Availability
PC Connection
USB 2.0
Office Machine Features
Scan to e-mail, scan to folder
AC 230 V ( 50/60Hz )
39 cm x 36.1 cm x 36.2 cm
9.7 kg
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
10000 impressions
1500 pages
PC Connection
USB 2.0
Standard Memory
64 MB
Copying
Max Copying Speed
Up to 20 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, 4 on 1
Printing
Max Printing Speed
Up to 20 ppm
Image Enhancement Technology
1200 IQ
First Print Out Time B/W
8.5 sec
Scanning
Optical Resolution
600 x 600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR
Reception Memory Capacity
Up to 150 pages
PC Faxing
Document & Media Handling
Min Original Size
140 x 210 mm
Max Original Size
216 x 356 mm
Original Type
Sheets
40 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
250 sheets
100 sheets
Input tray - 250 sheets size: 140 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 40 sheets size: 140 x 210 mm - 216 x 356 mm weight: 60 g/m² - 105 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 20 ppm ( A4 ) - B/W , Copying: up to 20 ppm ( A4 ) - B/W , Scanning: up to 18 ppm ( A4 ) - B/W , Scanning: up to 6 ppm ( A4 ) - colour
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5 or later, Windows 8
307 Watt
Power Consumption Standby
7 Watt
Power Consumption Sleep
3 Watt
Warm Up Time
28 sec
First Copy Out Time B/W
14 sec
Consumables Included
1 x Cartridge ( black ) - up to 700 pages
TUV, GS
39 cm
36.1 cm
36.2 cm
9.7 kg
Sound Emission
28 dBA (idle) / 50 dBA (operating)
Scroll to top
