BT.com
Wishlist
Kyocera Fax System
Kyocera Fax System
£292.87
Kyocera Fax System
Kyocera Fax System
Hurry, only 1 left in stock!
£292.87
Add to wishlist
Delivery
Standard 1-3 working days
Kyocera Fax interface card. 33.6 Kbps - for Kyocera FS-6025, FS-6030, FS-6525 and FS-6530.
Kyocera Fax System (U) - fax interface card
Fax interface card
Internal
Max Transfer Rate
33.6 Kbps
Max Fax Transfer Rate
33.6 Kbps
Data Compression Protocol
MH, MMR, MR, JBIG
Kyocera FS-6025MFP, FS-6025MFP/Base, FS-6025MFP/FAX, FS-6025MFP/KL3, FS-6025MFP/KL3FAX, FS-6030MFP, FS-6030MFP/FAX, FS-6030MFP/KL3, FS-6030MFP/KL3FAX, FS-6525MFP/KL3, FS-6525MFP/KL3FAX, FS-6530MFP, FS-6530MFP/KL3, FS-6530MFP/KL3FAX
Fax interface card
Internal
Modem
Wired
12 MB
Max Transfer Rate
33.6 Kbps
MH, MMR, MR, JBIG
33.6 Kbps
Compatible Slots
1 x Expansion Slot
Scroll to top
