BT.com
Wishlist
Kyocera ECOSYS P7040CDN Colour Laser 40PPM Printer
Kyocera ECOSYS P7040CDN Colour...
£852.48
£852.48
Add to wishlist
Delivery
Standard Due date unavailable
With an astoundingly high print speed and extraordinary low cost per page, this productive printer knows how to impress. Its amorphous silicon drum has an extremely long lifetime and makes it an exceptionally economical device. Additionally, it can be equipped with a total of five paper trays – supporting flexible paper handling and long print runs.
Key Features:
  • Higher print speed (40ppm).
  • Enhanced printer solution capability.
    • 5 line LCD display and alphanumeric keypad.
    • Optional card reader support.
    • FollowMe print support in conjunction with KYOCERA Net Manager.
  • Up to 2,100 sheet paper input via 5 trays.
  • Mobile print support including KYOCERA Mobile Print and Mopria certified for iOS and Android devices.
  • Apple Airprint and Google Cloud Print support.
  • Three tier billing supported.
  • Highly secure with SSL, IPsec and Private Print functionality.
  • Support of optional IB-50 and IB-51 for network and wireless printing.
  • Additional SD and SSD memory.
  • Long-life aSi drum for 300,000 pages.
  • Highest capacity toner boxes (12K colour and 16K black) for the lowest TCO in the range.
Kyocera ECOSYS P7040cdn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
30.5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 40 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
9600 x 600 dpi
Max Resolution (Colour)
9600 x 600 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
PowerPC 465S 1 GHz
RAM Installed (Max)
512 MB (2 GB)
Card Reader
Language Simulation
PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, XPS, PDF 1.7, PRESCRIBE IIc
Barcodes
UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
Media Type
Plain paper
Total Media Capacity
600 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray
Monthly Duty Cycle (max)
150000 pages
Print server
Printer Features
Kyocera ECOSYS Technology
AC 230V
39 cm x 53.2 cm x 46.95 cm
Printer Type
Printer
Print Speed
Wired
AirPrint Enabled
9600 x 600 dpi
9600 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6 sec
First Print Out Time Colour
7 sec
Language Simulation
Fonts Included
93 x scalable , 1 , 45 x barcode
Barcodes
Printer Features
Media Handling
PowerPC 465S 1 GHz
RAM
RAM Installed (Max)
512 MB / 2 GB (max)
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
Media Weight
60 g/m² - 220 g/m²
600 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Max Media Capacity
2100 sheets
Output Trays Capacity
500 sheets
Duty Cycle
150000 pages
Print server
Remote Management Protocol
SNMP 3, HTTPS, IPPS
Security Protocols & Features
SSL, IPsec
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
TUV, ISO 9001, GS, ISO 14001, ISO 7779
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
661 Watt
Power Consumption Stand by
83 Watt
Power Consumption Sleep
2.1 Watt
Environmental Standards
ENERGY STAR
39 cm
53.2 cm
46.95 cm
30.5 kg
Scroll to top
