BT.com
Wishlist
Kyocera ECOSYS P7035cdn Colour Laser Printer
Delivery
Standard Due date unavailable
As one of the most compact printers in the high-speed segment, the ECOSYS P7035cdn knows how to impress with astoundingly high print volumes. Thanks to its amorphous silicon drum with an unrivaled long lifetime, the printer is an exceptionally economical device. In order to fulfill even the highest user demands, this device can be equipped with a total of 6 paper trays for flexible paper handling. In order to fulfill even the highest user demands, this device can be equipped with a total of 6 paper trays for flexible paper handling.
Kyocera ECOSYS P7035cdn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
35 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 138 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 35 ppm - B/W - A4 (210 x 297 mm) , Up to 35 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
9600 x 600 dpi
Max Resolution (Colour)
9600 x 600 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
PowerPC 465S 667 MHz
RAM Installed (Max)
512 MB (1536 MB)
Card Reader
Language Simulation
PCL 5C, PCL 6, PCL XL, KPDL3, PRESCRIBE IIe, XPS, PDF 1.7
Barcodes
UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
Media Type
Plain paper
Total Media Capacity
650 sheets
Media Handling
150-sheet bypass tray, 500-sheet input tray
Monthly Duty Cycle (max)
150000 pages
Print server
Printer Features
Kyocera ECOSYS Technology
AC 230V
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.4 or later
34.5 cm x 51.8 cm x 51.2 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
AirPrint Enabled
9600 x 600 dpi
9600 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
8 sec
First Print Out Time Colour
9 sec
Language Simulation
Fonts Included
93 x scalable PCL , 93 x scalable PostScript , 1 x bitmapped , 45 x barcode
Barcodes
Printer Features
Media Handling
RAM
RAM Installed (Max)
512 MB / 1536 MB (max)
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 138 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
Media Weight
60 g/m² - 220 g/m²
650 sheets
Media Feeders
1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
Max Media Capacity
2650 sheets
Output Trays Capacity
500 sheets
Duty Cycle
150000 pages
Print server
Remote Management Protocol
SNMP 3, HTTPS, IPPS
Security Protocols & Features
SSL, IPsec
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 6000 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 5000 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 5000 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 5000 pages ISO/IEC 19798
TUV, ISO 9001, GS, ISO 14001, ISO 7779
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
622 Watt
Power Consumption Stand by
86 Watt
Power Consumption Sleep
4 Watt
Environmental Standards
ENERGY STAR
Sound Emission (Idle)
33.7 dBA
Sound Emission (Operating)
53.2 dBA
34.5 cm
51.8 cm
51.2 cm
35 kg
Scroll to top
