BT.com
Wishlist
Kyocera ECOSYS P6021cdn Colour Laser Printer
Kyocera ECOSYS P6021cdn Colour...
Free delivery
£210.60
Free delivery
£25 Cashback Available!
£210.60
Add to wishlist
Delivery
Standard Due date unavailable
Providing small teams and demanding users with high-quality color prints. The ECOSYS P6021cdn is a compact device with low noise output, which makes it the ideal business companion for any office. It has an integrated duplex unit as standard for effortless double sided printing. It combined with improved energy efficiency: these features help you reduce the impact of your printing activities on the environment. Its long life components reduce waste and make this printer the reliable business companion of choice!
Kyocera ECOSYS P6021cdn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
29.3 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 26 ppm - B/W - A4 (210 x 297 mm) , Up to 26 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
9600 x 600 dpi
Max Resolution (Colour)
9600 x 600 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
PowerPC 465S 667 MHz
RAM Installed (Max)
512 MB (1536 MB)
Card Reader
Language Simulation
PCL 5C, PCL 6, PCL XL, KPDL3, PRESCRIBE IIe, XPS, PDF 1.7
Barcodes
UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
Media Type
Plain paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
1000 - 1667 pages
Print server
Printer Features
Kyocera ECOSYS Technology
AC 230V
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.4 or later
Environmental Standards
EPEAT Silver
39 cm x 52.3 cm x 37 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
AirPrint Enabled
9600 x 600 dpi
9600 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
10.5 sec
First Print Out Time Colour
12 sec
Language Simulation
Fonts Included
93 x scalable , 1 x bitmapped , 45 x barcode
Barcodes
Printer Features
Media Handling
RAM
RAM Installed (Max)
512 MB / 1536 MB (max)
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
Media Weight
60 g/m² - 220 g/m²
300 sheets
Media Feeders
1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - 216 x 297 mm weight: 60 g/m² - 163 g/m²
Max Media Capacity
1300 sheets
Output Trays Capacity
250 sheets
Duty Cycle
50000 pages
1000 - 1667 pages
Print server
Remote Management Protocol
SNMP 3, HTTPS, IPPS
Security Protocols & Features
SSL, IPsec
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 1200 pages , 1 x toner cartridge (cyan) - up to 1200 pages , 1 x toner cartridge (magenta) - up to 1200 pages , 1 x toner cartridge (yellow) - up to 1200 pages
TUV, ISO 9001, GS, ISO 14001, ISO 7779
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
353 Watt
Power Consumption Stand by
61 Watt
Power Consumption Sleep
4 Watt
EPEAT Compliant
EPEAT Silver
ENERGY STAR
Sound Emission (Operating)
48.2 dBA
39 cm
52.3 cm
37 cm
29.3 kg
Scroll to top
