BT.com
Wishlist
Kyocera ECOSYS P3060dn A4 Mono Laser Printer
Kyocera ECOSYS P3060dn A4 Mono...
£747.78
£747.78
Add to wishlist
Delivery
Standard 1-3 working days
As the premium model in this series, the ECOSYS P3060dn has it all. It boasts high-speed printing with 60 pages per minute, only 4.9 seconds to print the first page and a maximum paper capacity of up to 2,600 sheets. And with reliability that is second to none, thanks to the long-life components, you can rely on this ECOSYS printer to deliver low total cost of ownership and or exceptionalluy low environmental impact.
  • Up to 60 pages per minute A4 and A5
  • Time to first print: only 4.9 seconds
  • Standard Gigabit LAN, Wi-Fi option with Wi-Fi Direct available
  • Mobile Printing support for AirPrint, Mopria, KYOCERA Mobile Print
  • Double-sided and N-up printing for less paper consumption
  • Up to 6 paper trays for superior flexibility and high capacity
  • Optimal document distribution and workflow with optional Print&FollowTM
  • Data Security Kit provides high level security for optional HD-6/HD-7
  • Environmentally friendly: long-life components, low energy consumption
  • Exceptionally-low printing costs in its class
Kyocera ECOSYS P3060DN - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
15.5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm)/A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 60 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
1.2 GHz
RAM Installed (Max)
512 MB (2560 MB)
Language Simulation
PCL 5C, PostScript 3, IBM X24E, PCL 6, PCL XL, KPDL3, PRESCRIBE IIe, XPS, EPSON LQ 850, PDF 1.7
Barcodes
UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
Media Type
Plain paper
Total Media Capacity
600 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray
Monthly Duty Cycle (max)
275000 pages
Print server
Printer Features
Kyocera ECOSYS Technology, Mopria certified
AC 230V
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.8 or later
1 year warranty
39.6 cm x 42.1 cm x 34.2 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
4.9 sec
Language Simulation
Fonts Included
93 x scalable , 1 x bitmapped , 45 x barcode
Barcodes
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
512 MB / 2560 MB (max)
Card Reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Media Weight
60 g/m² - 220 g/m²
600 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
Max Media Capacity
2600 sheets
Output Trays Capacity
500 sheets
Duty Cycle
275000 pages
Print server
Remote Management Protocol
SNMP 3, HTTPS, IPPS
Security Protocols & Features
Secure Print, SSL, IPsec
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 10000 pages ISO/IEC 19752
TUV GS, ISO 9001, ISO 14001, ISO 7779, ISO 9296
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
684 Watt
Power Consumption Stand by
11 Watt
Power Consumption Sleep
0.8 Watt
Software Included
Google Cloud Print
Environmental Standards
ENERGY STAR
Limited warranty - 1 year , Limited warranty - drum - 3 years or 500,000 pages
Sound Emission (Idle)
27.1 dBA
Sound Emission (Operating)
56 dBA
Sound Emission (Quiet Mode)
51.5 dBA
39.6 cm
42.1 cm
34.2 cm
15.5 kg
Scroll to top
