BT.com
Wishlist
Kyocera ECOSYS P2135dn Mono Laser Printer
Delivery
Standard Due date unavailable
A printer you'll gladly share a room with! The KYOCERA ECOSYS P2135dn desktop printer has a silent printing option, ensuring that the printer won't interfere with your work. Moreover, its network connectivity and high security standards secure your documents during the whole printing process. It prints up to 35 pages per minute and will easily handle large print runs; its LCD control panel gives you clear messages about the device's status. Robust, highly reliable and very economical, the ECOSYS P2135dn is a printer you can really count on.
Kyocera ECOSYS P2135dn - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
12 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 35 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
PowerPC 440F5 500 MHz
RAM Installed (Max)
256 MB (1280 MB) - DDR2 SDRAM
Language Simulation
PCL 5E, IBM X24E, PCL XL, Diablo 630, KPDL3, PDF, PRESCRIBE IIe, XPS, EPSON LQ 850
Barcodes
PDF417
Media Type
Plain paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
2000 pages
Print server
Printer Features
Kyocera ECOSYS Technology
AC 230V
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.5 or later
37.5 cm x 39.3 cm x 26.7 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
AirPrint Enabled
1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
8 sec
Language Simulation
Barcodes
PDF417
Printer Features
Media Handling
RAM
RAM Installed (Max)
256 MB / 1280 MB (max)
Technology / Form Factor
DDR2 SDRAM
Slots Qty
1
Empty Slots
1
Card Reader
Supported Flash Memory Cards
SD Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), Oficio (216 x 343 mm)
Media Weight
60 g/m² - 220 g/m²
300 sheets
Media Feeders
1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 250 sheets - 216 x 297 mm weight: 60 g/m² - 120 g/m²
Max Media Capacity
800 sheets
Output Trays Capacity
250 sheets
Duty Cycle
50000 pages
2000 pages
Print server
Remote Management Protocol
SNMP 3, HTTPS, IPPS
Security Protocols & Features
SSL, IPsec
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 2300 pages ISO/IEC 19752
TUV, ISO 9001, GS, ISO 14001, ISO 7779
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
535 Watt
Power Consumption Stand by
11 Watt
Power Consumption Sleep
2.5 Watt
Environmental Standards
ENERGY STAR
Sound Emission (Idle)
53.5 dBA
37.5 cm
39.3 cm
26.7 cm
12 kg
Scroll to top
