BT.com
Wishlist
Kyocera ECOSYS P2040dw A4 Mono Laser Printer
Kyocera ECOSYS P2040dw A4 Mono...
£240.04
17 in stock
£240.04
Add to wishlist
Delivery
Standard 1-3 working days
A productive solution for workgroups that require a wide variety of output sizes from A6 up to A3. This fast and compact printer offers an expandable paper capacity of up to 6 paper trays for flexible paper handling. Plus this team-player knows exactly how to impress with comprehensive security features and ECOSYS long-life technology that gives you exceptionally low cost per page and less waste.
Kyocera ECOSYS P2040dw - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
14 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 40 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host, Wi-Fi
800 MHz
RAM Installed (Max)
256 MB (256 MB)
Language Simulation
PCL 5E, PostScript 3, PCL 6, PCL XL, KPDL3, PRESCRIBE IIe, XPS
Barcodes
UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
Media Type
Plain paper
Total Media Capacity
350 sheets
Media Handling
100-sheet multipurpose tray, 250-sheet input tray
Print server
Printer Features
Kyocera ECOSYS Technology
AC 230V
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.5 or later
1 year warranty
37.5 cm x 39.3 cm x 27.2 cm
Printer Type
Printer
Print Speed
Wireless
1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6.4 sec
Language Simulation
Fonts Included
80 x scalable , 1 x bitmapped , 45 x barcode
Barcodes
Printer Features
Media Handling
800 MHz
RAM
RAM Installed (Max)
256 MB / 256 MB (max)
Card Reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), Oficio (216 x 343 mm)
Media Weight
60 g/m² - 220 g/m²
350 sheets
Media Feeders
1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 250 sheets - 216 x 297 mm weight: 60 g/m² - 120 g/m²
Max Media Capacity
850 sheets
Output Trays Capacity
250 sheets
Print server
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
TUV, ISO 9001, GS, ISO 14001, ISO 7779
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
620 Watt
Power Consumption Stand by
8 Watt
Power Consumption Sleep
0.8 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
Sound Emission (Operating)
48.8 dBA
37.5 cm
39.3 cm
27.2 cm
14 kg
Scroll to top
