BT.com
Wishlist
Kyocera ECOSYS P2035dn A4 Mono Laser Printer
Delivery
Standard Due date unavailable
A reliable and robust office solution for perfect between printing day in, day out! The ECOSYS P2035d desktop printer is very compact and its standard duplex printing functionality helps you reduce your paper consumption. You can also regulate its noise level according to your needs. It has long life components that reduce downtime and large paper cassettes holding up to 550 sheets. It will carry out daily office tasks without hassle or noise. This printer is a perfect companion for busy days: discreet, hardworking and reliable!
Kyocera ECOSYS P2035dn - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
12 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 35 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1800 x 600 dpi
Automatic Duplexing
USB 2.0, LAN
PowerPC 405F5 360 MHz
RAM Installed (Max)
32 MB (544 MB)
Language Simulation
PCL 5E, PCL 6, PCL XL, Diablo 630, KPDL3, PRESCRIBE IIe, EPSON LQ 850, IBM ProPrinter X24e
Barcodes
UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
Media Type
Plain paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
20000 pages
Recommended Monthly Volume
2000 pages
Print server
Printer Features
Kyocera ECOSYS Technology
AC 230V
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.5 or later
37.5 cm x 39.3 cm x 25 cm
Printer Type
Printer
Print Speed
Wired
USB 2.0, LAN
1800 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6 sec
Language Simulation
Fonts Included
80 x scalable , 1 x bitmapped , 45 x barcode
Barcodes
Printer Features
Media Handling
RAM
RAM Installed (Max)
32 MB / 544 MB (max)
Slots Qty
1
Empty Slots
1
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), Oficio (216 x 343 mm)
Media Weight
60 g/m² - 220 g/m²
300 sheets
Media Feeders
1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 250 sheets - 216 x 297 mm weight: 60 g/m² - 120 g/m²
Max Media Capacity
550 sheets
Output Trays Capacity
250 sheets
Duty Cycle
20000 pages
2000 pages
Print server
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19752
TUV, ISO 9001, GS, ISO 14001, ISO 7779
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
535 Watt
Power Consumption Stand by
7.1 Watt
Power Consumption Sleep
2.6 Watt
Environmental Standards
ENERGY STAR
Sound Emission (Idle)
30.7 dBA
Sound Emission (Operating)
53.3 dBA
Sound Emission (Quiet Mode)
49.6 dBA
37.5 cm
39.3 cm
25 cm
12 kg
Scroll to top
