BT.com
Wishlist
Kyocera ECOSYS M6530cdn A4 Colour Laser Multifunction Printer
Kyocera ECOSYS M6530cdn A4 Colour...
£681.28
Hurry, only 3 left in stock!
£681.28
Add to wishlist
Delivery
Standard 1-3 working days
These productive multifunctional devices offer fast print speeds and a short wait for the first copy. Their high input capacity and exceptional scanning performance make large digitization projects a breeze. And thanks to their minimum downtime - based on the KYOCERA long-life components - plus full duplex support, they are ideal for busy, environmentally aware offices.
Kyocera ECOSYS M6530cdn - multifunction printer (colour)
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
100000 pages
Max Copying Speed
Up to 30 ppm (mono) / up to 30 ppm (colour)
Max Printing Speed
Max Printing Resolution
Up to 9600 x 600 dpi (mono) / up to 9600 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Original Size
Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
350 sheets
Max Media Capacity
1850 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to network, scan to FTP, scan to SMB
AC 230 V (50/60Hz)
47.5 cm x 55.8 cm x 61.6 cm
34.7 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
100000 pages
Display
5 lines
PC Connection
AirPrint Enabled
Standard Memory
1024 MB
Max Supported Memory
2048 MB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Control
Automatic, manual
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, KPDL3, PCL XL, PDF 1.7, XPS
Automatic Duplexing
First Print Out Time B/W
7 sec
First Print Out Time Colour
8.5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Reception Memory Capacity
Up to 256 pages
Fax Machine Features
One-Touch Dialing
22 station(s)
Fax polling, Duplex Fax
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 70 x 148 mm
350 sheets
Max Media Capacity
1850 sheets
100 sheets
250 sheets
Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , ADF - 75 sheets size: 140 x 210 mm - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 250 sheets
Speed Details
Printing: up to 30 ppm (A4) - B/W , Printing: up to 30 ppm (A4) - colour , Copying: up to 30 ppm (A4) - B/W , Copying: up to 30 ppm (A4) - colour , Scanning: up to 40 ipm (A4) - B/W , Scanning: up to 30 ipm (A4) - colour
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, IPsec, 802.1x
Operating System Support
UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
AC 230 V (50/60Hz)
510 Watt
Power Consumption Sleep
2.1 Watt
Warm-Up Time
26 sec
First Copy Out Time B/W
9.5 sec
First Copy Out Time Colour
11.5 sec
Consumables Included
1 x Cartridge (black) - up to 3500 pages , 1 x Cartridge (cyan) - up to 2500 pages , 1 x Cartridge (magenta) - up to 2500 pages , 1 x Cartridge (yellow) - up to 2500 pages
TUV, ISO 9001, GS, ISO 14001, ISO 7779
ENERGY STAR Certified
Limited warranty - 1 year
47.5 cm
55.8 cm
61.6 cm
34.7 kg
Scroll to top
