BT.com
Wishlist
Kyocera ECOSYS M2030dn A4 Mono Multifunction Laser Printer
Kyocera ECOSYS M2030dn A4 Mono...
£254.07
£254.07
Add to wishlist
Delivery
Standard Due date unavailable
The compact A4 MFP can increase the productivity of any office. It has print and copy speeds of up to 30 pages per minute and a time to first print of only 6 seconds. The large-capacity document processor scans double-sided originals and makes it easy to master large digitization projects. You can quickly and easily access all the functionalities needed via the well-structured 5-line LCD display.
  • Up to 30 pages per minute in A4
  • Time to first copy: 6.9 seconds
  • 5-line LCD display for clear messages and ease of use
  • Print, copy, scan functionality as standard
  • Duplex unit for cost-saving double-sided printing
  • 50-sheet document processor scans double-sided originals
  • Copy double sided ID cards on a single sheet of paper with ease
  • Exceptionally low printing costs in its class
Kyocera ECOSYS M2030dn - multifunction printer (B/W)
Printer / copier / scanner
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
20000 images
Max Printing Speed
Up to 30 ppm
Max Printing Resolution
Up to 1800 x 600 dpi
Scanning
600 dpi
Original Size
140 x 210 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
300 sheets
Max Media Capacity
800 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, Kyocera ECOSYS Technology
AC 230 V (50/60Hz)
49.4 cm x 43 cm x 44.8 cm
18 kg
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Laser - monochrome
20000 images
Display
5 lines
PC Connection
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
1536 MB
Supported Flash Memory
SD Memory Card
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, Sort, Multiple Copy
Printing
Max Printing Speed
Up to 30 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, KPDL3, PCL XL, PDF 1.7, XPS, EPSON LQ-850, IBM Proprinter X24E, Lineprinter
Automatic Duplexing
First Print Out Time B/W
7 sec
Scanning
Automatic Duplexing
Optical Resolution
600 dpi
Grey Scale Depth
8 bit
Document & Media Handling
Min Original Size
140 x 210 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
300 sheets
Max Media Capacity
800 sheets
50 sheets
150 sheets
Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² weight (lbs): , Bypass tray - 50 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² weight (lbs): , ADF - 50 sheets size: 140 x 210 mm - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² weight (lbs): , Output tray - 150 sheets weight (lbs):
Speed Details
Printing: up to 30 ppm (A4) - B/W , Scanning: up to 35 ipm (A4) - B/W , Scanning: up to 14 ipm (A4) - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
LDAP, SSL, IPsec
Operating System Support
UNIX, Linux, Apple MacOS X 10.4 or later, MS Windows
AC 230 V (50/60Hz)
431 Watt
Power Consumption Standby
62 Watt
Power Consumption Sleep
3.7 Watt
Warm Up Time
20 sec
First Copy Out Time B/W
6.9 sec
Consumables Included
1 x Cartridge (black) - up to 1000 pages
TUV, ISO 9001, GS, ISO 14001, ISO 7779
49.4 cm
43 cm
44.8 cm
18 kg
Sound Emission
28.3 dBA (idle) / 50.4 dBA (operating)
Scroll to top
