BT.com
Wishlist
Konftel 300Wx Wireless Expandable Conference Phone
Konftel 300Wx Wireless Expandable...
£482.53
Hurry, only 1 left in stock!
£482.53
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Monday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The Konftel 300Wx allows you to hold conference calls where and when it is convenient - without worrying about phone jacks and power outlets. The rechargeable lithium ion battery ensures superior performance with long talk time, this allows a full working week without worrying about recharging! The Konftel 300Wx supports DECT with GAP/CAT-Iq standard for less interference and clearer conversations and moreover is easily integrated with existing DECT systems for complete coverage. The Konftel 300Wx can also be easily connected to your cell phone or computer via USB for VoIP calls over the Internet. Its embedded line mode enables you to connect DECT, cell phones and USB simultaneously for multi-party calls. The Konftel 300Wx has several smart features to make your meetings as easy and efficient as possible. Record calls on a SD memory card, listen to it later or share it with others. The built-in conference guide helps you dial multi-party calls, store call groups and initiate reoccurring meetings. The Konftel 300Wx is expandable with microphones, equipped with Konftel OmniSound audio technology for crystal clear sound and its elegant Scandinavian design makes it a welcome addition to any conference room.
Konftel 300Wx - cordless conference phone
Cordless conference phone
Cordless Phone Standard
DECT\GAP
Package Content
Conference phone console, Conferencing base unit
Speakerphone
Yes (digital duplex)
Call Services
Call Hold
Display
LCD display - monochrome - Yes
Body Colour
Liquorice black
Europe
2 years warranty
Body Colour
Liquorice black
Europe
Phone Features
DECT\GAP
Call Services
Call Hold
Max Handsets Supported
7
Max Handset Operating Distance
50 m
Max Handset Operating Distance (Outdoor)
200 m
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
3-way
Speakerphone
Voice Recording
Menu Operation
Computer Link
Yes (USB)
Firmware Upgradable
Additional Functions
Built-in clock, voice recording
Additional Features
PIN code, built-in SD card slot
Conference Phone
Package Content
USB connection for VoIP calls, OmniSound HD
Phone Memory
Phone Directory Capacity
200 names & numbers
Display
Display Location
Base
Display Resolution
128 x 64 pixels
Backlit
Supported Flash Memory Cards
SD Memory Card
USB / mini-USB Type B , 2 x microphone jack , Cellular phone connection headset jack
USB cable - 1.5 m , Power cable - 7.5 m
Charging stand, phone base, power adapter
EN 301.489.1, FCC Part 68, EN 301.489.6, IEC 60950-1, EN 60950-1, EN 301.406
5200 mAh
Rechargeable - Lithium Ion
Included Qty
1
Talk Time
Up to 3600 min
Standby Time
Up to 270 h
Dimensions & Weight (Base)
24 cm
24 cm
7.7 cm
1 kg
Scroll to top
