BT.com
Wishlist
Kodak SCANMATE i940 Document Scanner
Kodak SCANMATE i940 Document...
£265.02
28 left in stock
£265.02
Add to wishlist
Delivery
Standard 1-3 working days
The only thing worse than data trapped on paper is information trapped in your computer. With the compact Kodak Scanmate i940 scanner, collecting, managing, and distributing information is simple and desktop-friendly.
Kodak's smart touch functionality replaces complicated multi-step scanning processes with one-touch simplicity. So, you get compact with a huge impact.
Create email attachments, picture files, and searchable PDFs - and get your documents to the cloud, so they can be accessed wherever you are. With the i940, you can scan directly to cloud-based applications.
And, the USB-powered capability lets you bring all this functionality with you, wherever you go. Capture, process, and send information effortlessly.
Kodak SCANMATE i940 - document scanner
Document scanner - desktop
Interface Type
USB 2.0
Max Supported Document Size
216 x 1524 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
20 ppm (mono) / 15 ppm (colour)
Max Document Size
216 mm x 1524 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
20 sheets
Duty Cycle
500 scans per day
Microsoft Windows Vista (32/64 bits) SP1, Microsoft Windows 7 (32/64 bits) SP1, Microsoft Windows XP (32/64 bits) SP3
Microsoft Certification
Compatible with Windows 7
29 cm x 10.7 cm x 7.9 cm
1.3 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Interface Type
USB 2.0
216 x 1524 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Max Document Scan Speed B/W
20 ppm
Max Document Scan Speed Colour
15 ppm
Duty Cycle
500 scans per day
Scanner Speed Details
20 ppm - portrait B&W - Letter - 200 dpi , 20 ppm - portrait greyscale - Letter - 200 dpi , 15 ppm - portrait colour - Letter - 200 dpi , 40 ipm - duplex - portrait B&W - Letter - 200 dpi , 40 ipm - duplex - portrait greyscale - Letter - 200 dpi , 30 ipm - duplex - portrait colour - Letter - 200 dpi , 8 ppm - portrait B&W (USB bus powered) - Letter - 200 dpi , 8 ppm - portrait greyscale (USB bus powered) - Letter - 200 dpi , 8 ppm - portrait colour (USB bus powered) - Letter - 200 dpi
Scanner Features
Powered by USB port, Color Dropout, Blank Page Removal, Auto Crop, Auto Deskew
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 1524 mm
Automatic
20 sheets
USB 2.0 - Type B
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Internal power supply
Software Included
Drivers & Utilities, Presto! BizCard, KODAK Smart Touch
29 cm
10.7 cm
7.9 cm
1.3 kg
Limited warranty - replacement - 3 years - response time: next business day
Scroll to top
