BT.com
Wishlist
Kodak PS50 Picture Saver Scanning System
Delivery
Standard Due date unavailable
Say goodbye to the days of slow flatbed scanning! Scanning pictures and other memorabilia is now fast and easy - with great profit potential - thanks to the Kodak Picture Saver Scanning Systems PS50. Just think - while it used to take one to two minutes to scan a single photo on a flatbed, you can now scan up to 85 photos in just one minute! And the image quality and automatic enhancements are simply dazzling, thanks to easy-to-use, intuitive Kodak picture saver scanning software.
Kodak Picture Saver Scanning System PS50 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Dual CCD
Light Source
Dual LED
Max Supported Document Size
215 x 863 mm
Input Type
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
50 ppm (mono) / 50 ppm (colour)
Max Document Size
302 mm x 461 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Microsoft Windows Vista (32/64 bits) SP2, Microsoft Windows XP SP3, Microsoft Windows XP 64-bit Edition SP2, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
33 cm x 16.2 cm x 24.6 cm
5.5 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
215 x 863 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
Dual CCD
Bulb / Light Source Type
Dual LED
Max Document Scan Speed B/W
50 ppm
Max Document Scan Speed Colour
50 ppm
Scanner Speed Details
50 ppm - landscape - 10x15cm - 300 dpi
Scanner Features
Color Dropout, Automatic Image Orientation, automatic colour detection, Auto Crop, iThresholding, Perfect Page, dual-stream scanning, adaptive threshold processing, Deskew
TWAIN
Media Handling
Max Document Size
302 mm x 461 mm
Plain paper
Automatic
50 sheets
USB 2.0
Dust cover
GOST, CISPR 22 Class B, cUL, EN 61000-3-3, EN55024, EN55022 Class B, CCC, FCC CFR47 Part 15 B, S Mark, GB 4943, GB 9254 Class B, GB 17625.1, CAN/CSA C22.2 No. 60950-1-07, AS/NZS, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, ICES-003 issue 4 Class B, UL 60950-1-07
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
32 Watt (0.35 Watt)
Software Included
Drivers & Utilities, KODAK Smart Touch
33 cm
16.2 cm
24.6 cm
5.5 kg
10 °C
35 °C
15 - 76%
Scroll to top
