BT.com
Wishlist
Kodak I4850 A4 Document Scanner
£22,198.39
£22,198.39
Add to wishlist
Delivery
Standard Due date unavailable
Busy mailrooms, production departments and service bureaus have relied on KODAK i4000 Series Scanners for years to deliver a valuable combination of quality, productivity, and affordability. They're a great choice for plowing through hours of uninterrupted scanning.
Speed through huge jobs with time-saving features and the muscle to handle up to 125,000 scans a day. Larger interactive control panel lets operators do more without leaving the scanner for the host PC. Manage multi-feeds, avoid document damage and reduce the need for rescans with Intelligent Document Protection and auto image rotation. Control the most complicated workflows on the fly with advanced barcode reading.
Kodak i4850 - document scanner
Document scanner - desktop
Interface Type
USB 3.0
Scan Element Type
CCD
Light Source
White LED array
Max Supported Document Size
304.8 x 5300 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
150 ppm (mono) / 150 ppm (colour)
Max Document Size
304.8 mm x 5300 mm
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
500 sheets
Duty Cycle
125000 scans per day
Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Ubuntu 14.04 LTS, Ubuntu 14.04 LTS (64-bit)
48.9 cm x 46.73 cm x 34.79 cm
30.4 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 3.0
304.8 x 5300 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Scan Element Type
CCD
Bulb / Light Source Type
White LED array
Max Document Scan Speed B/W
150 ppm
Max Document Scan Speed Colour
150 ppm
Duty Cycle
Scanner Speed Details
150 ppm - landscape B&W - 200 dpi , 150 ppm - landscape colour - 300 dpi
Scanner Features
Multi Color Dropout, Automatic Image Orientation, iThresholding, Perfect Page, dual-stream scanning, Punch Hole Removal, Intelligent Document Protection, Intelligent Imprinting
TWAIN, ISIS, WIA
Media Handling
Max Document Size
304.8 mm x 5300 mm
Plain paper
Automatic
500 sheets
USB 3.0 - Type B
Internal power supply
Power Consumption Operational (Standby)
130 Watt
Power Consumption Stand by
1.5 Watt
Power Consumption Sleep
0.5 Watt
Software Included
KODAK Capture Pro Software Limited Edition
48.9 cm
46.73 cm
34.79 cm
30.4 kg
Sound Emission
63 dBA
Scroll to top
