BT.com
Wishlist
Kodak i2900 A4 Document Scanner
Delivery
Standard 1-3 working days
The Kodak i2900 scanner is a robust rotary A4 desktop scanner with an ingenious book-edge flatbed scanner built right in. It features a 250-sheet feeder/elevator and consistently high throughput speed, even when imaging double-sided and color documents at up to 300 dpi. Add in intelligent document protection, as well as Kodak's Perfect Page technology and Smart Touch functionality, and you've got a fiercely powerful scanner in a remarkably compact package.
Kodak i2900 - document scanner
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Dual CCD
Light Source
Dual LED
Max Supported Document Size
216 x 4064 mm
Input Type
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
60 ppm (mono) / 60 ppm (colour)
Max Document Size
216 mm x 4064 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
250 sheets
Duty Cycle
10000 scans per day
Microsoft Windows Vista (32/64 bits) SP2, Ubuntu 10.04, Microsoft Windows 7 (32/64 bits) SP1, Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits)
43.18 cm x 37.1 cm x 23.75 cm
15.8 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 4064 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Automatic Duplexing
Scan Element Type
Dual CCD
Bulb / Light Source Type
Dual LED
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
60 ppm
Duty Cycle
10000 scans per day
Scanner Speed Details
60 ppm - portrait B&W - Letter - 300 dpi , 120 ipm - duplex - portrait B&W - Letter - 300 dpi , 60 ppm - portrait greyscale - Letter - 300 dpi , 120 ipm - duplex - portrait greyscale - Letter - 300 dpi , 60 ppm - portrait colour - Letter - 300 dpi , 120 ipm - portrait colour - Letter - 300 dpi
Scanner Features
Color Dropout, Ultrasonic Double Feed Detection, Automatic Image Orientation, automatic colour detection, built-in LCD screen, Auto Crop, iThresholding, Perfect Page, dual-stream scanning, adaptive threshold processing, image merge, auto brightness, Deskew, Blank Page Detection
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 4064 mm
Plain paper
Automatic
250 sheets
USB 2.0
1 x USB cable
UL, TUV GS, C-Tick, cUL, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, CCC, UL 60950-1, IEC 60950-1, EN 60950-1, FCC CFR47 Part 15 B, S Mark, BSMI CNS 14336, GB 4943, GB 9254 Class B, GB 17625.1, CAN/CSA C22.2 No. 60950-1-07, AS/NZS, VCCI Class B
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
75 Watt (0.5 Watt)
Software Included
Drivers & Utilities, KODAK Capture Desktop Software, KODAK Smart Touch
System Requirements Details
Core 2 Duo RAM 3 GB
43.18 cm
37.1 cm
23.75 cm
15.8 kg
15 °C
35 °C
15 - 76%
Sound Emission
30 dBA
Scroll to top
