BT.com
Wishlist
Kodak I2820 A4 Colour Document Scanner
Kodak I2820 A4 Colour Document...
£949.45
£949.45
Add to wishlist
Delivery
Standard Due date unavailable
This is a duplex scanner that scans 70 pages per minute at 200 and 300 dpi in black and white and grayscale; and 40 pages per minute at 200 dpi in color. The i2820 scanner allows you to scan 100 documents at a time and the dual LED indirect light provides excellent image quality.
To keep your business process humming, you need a scanning solution that combines great image quality, simple operation and time-saving productivity. The Kodak i2000 Series Scanners offer all that in a very small yet powerful package.
Kodak i2820 - document scanner
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Dual CCD
Light Source
Dual LED
Max Supported Document Size
216 x 4064 mm
Input Type
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
70 ppm (mono) / 60 ppm (colour)
Max Document Size
216 mm x 4064 mm
Supported Document Type
Plain paper, business card
Document Feeder Type
Automatic
Document Storage Capacity
100 sheets
Duty Cycle
8000 scans per day
Microsoft Windows XP SP2, Microsoft Windows Vista (32/64 bits) SP1, Microsoft Windows XP SP3, Microsoft Windows Server 2008 x64 Edition, Microsoft Windows XP 64-bit Edition SP2, Ubuntu 10.04, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 (32/64 bits), Apple MacOS X 10.8, Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Apple MacOS X 10.10, Microsoft Windows Server 2012 (64-bit)
33 cm x 16.2 cm x 24.6 cm
5.5 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 4064 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Scan Element Type
Dual CCD
Bulb / Light Source Type
Dual LED
Max Document Scan Speed B/W
70 ppm
Max Document Scan Speed Colour
60 ppm
Duty Cycle
8000 scans per day
Scanner Speed Details
70 ppm - black & white - 300 dpi , 60 ppm - colour - 300 dpi , 70 ppm - black & white - 300 dpi , 60 ppm - colour - 300 dpi
Scanner Features
Automatic Image Orientation, Ultrasonic multifeed sensor, automatic colour detection
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 4064 mm
Automatic
100 sheets
USB 2.0 - Type A
TUV GS, C-Tick, VCCI Class B ITE, CISPR 22 Class B, BSMI CNS 13438 Class B, cUL, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-07, FCC CFR47 Part 15 B, S Mark, AS/NZS 3548 Class B, BSMI CNS 14336, GB 4943, GB 9254 Class B, GB 17625.1
Internal power supply
Power Consumption Operational (Standby)
32 Watt
Power Consumption Stand by
0.35 Watt
Power Consumption Sleep
4 Watt
System Requirements Details
Windows XP/Vista/7/8 - Core 2 Duo - 2.4 GHz - RAM 4 GB , MacOS - Core i7 - 2 GHz - RAM 4 GB
33 cm
16.2 cm
24.6 cm
5.5 kg
10 °C
35 °C
15 - 80%
Scroll to top
