BT.com
Wishlist
Kodak i1150 A4 Document Scanner
£318.09
12 in stock
£318.09
Add to wishlist
Delivery
Standard 1-3 working days
KODAK SCANMATE i1150 Scanner processes transactions at the speed of business. The transformation of information capture continues. Businesses must deal with more diverse sources of information than ever before. And yet paper remains an important input source. Companies are focused on generating efficiencies where the value of information capture from paper is greatest - in business transactions.
The KODAK SCANMATE i1150 Scanner is designed for use in customer-facing business transactions, where an employee needs to scan documents as part of a business process. Employees using these solutions are typically interacting with customers and need to keep the transaction moving to reduce wait times and increase customer satisfaction.
Recognizing that a majority of transactions involve 10 or fewer documents to be scanned, the KODAK SCANMATE i1150 Scanner features a special transaction mode, enabling 60 percent faster capture speed for the first 10 pages.
Scan documents and capture information, extract data, and handle documents once. Benefit from an intuitive, icon-based color interface. Take advantage of associated cost savings. And that's just the beginning.
Small, quiet, quick, and intelligently designed, the SCANMATE i1150 Scanner accelerates your processes with seamless technology so you can focus on your customers.
Kodak SCANMATE i1150 - document scanner
Document scanner - desktop
Interface Type
USB 3.0
Scan Element Type
CMOS / CIS
Light Source
Dual LED
Max Supported Document Size
215 x 355.6 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
30 ppm (mono) / 30 ppm (colour)
Max Document Size
215 mm x 355.6 mm
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
3000 scans per day
Microsoft Windows Server 2008, Ubuntu, Microsoft Windows Vista / XP / 7 / 8
Microsoft Certification
Compatible with Windows 7
33 cm x 16.2 cm x 24.6 cm
3.2 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Interface Type
USB 3.0
215 x 355.6 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Scan Element Type
CMOS / CIS
Bulb / Light Source Type
Dual LED
Max Document Scan Speed B/W
30 ppm
Max Document Scan Speed Colour
30 ppm
Duty Cycle
3000 scans per day
Scanner Speed Details
30 ppm - portrait B&W - 200 dpi , 30 ppm - portrait greyscale - 200 dpi , 30 ppm - portrait colour - 200 dpi , 30 ppm - portrait B&W - 300 dpi , 30 ipm - portrait greyscale - 300 dpi , 30 ipm - portrait colour - 300 dpi
Scanner Features
Built-in LCD screen, Colour Smoothing, Color Enhancement
TWAIN, ISIS, WIA
Media Handling
Max Document Size
215 mm x 355.6 mm
Plain paper
Automatic
50 sheets
USB 3.0
FCC Class B certified, TUV GS, VCCI Class B ITE, CISPR 22 Class B, cUL, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, CCC, UL 60950-1, IEC 60950-1, EN 60950-1, S Mark, GB 4943, GB 17625.1, AS/NZS, CAN/CSA C22.2 No. 60950-1-03
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
21 Watt (0.5 Watt)
Software Included
Drivers & Utilities
System Requirements Details
Core 2 Duo - 1 GHz - RAM 2 GB
33 cm
16.2 cm
24.6 cm
3.2 kg
Limited warranty - 3 years
15 °C
35 °C
15 - 80% (non-condensing)
Scroll to top
