BT.com
Wishlist
Kingston ValueRAM KVR667D2N5/1G ddr2 667 240pin dimm CL5
Kingston ValueRAM KVR667D2N5/1G...
£14.12
27 in stock
£14.12
Add to wishlist
Delivery
Standard 3-5 working days
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specs, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR2 - 1 GB - DIMM 240-pin
RAM memory
1 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
667 MHz ( PC2-5300 )
Latency Timings
CL5
Unbuffered
Voltage
1.8 V
Lead Plating
Gold
Limited lifetime warranty ( Germany, Austria and France - 10 years )
ASUS Commando Republic of Gamers, CROSSHAIR Republic of Gamers, M2N, M2N32, N4L; ECS 662/1066, 761, 945, 965, AMD480, AMD690, C19, C51, GeForce6100, K8M890, KA3, MCP55, NF650, NFORCE 570, NFORCE4M, NFORCE5M, P965, PA1, PF5, PF88, PN2, PX1, RC410L/800, RS482, RS485; Intel Desktop Board DG33, DP35
1 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
DIMM 240-pin
Module Height (inch)
1.25
Speed
Latency Timings
CL5
Non-ECC
Unbuffered
Module Configuration
128 x 64
Chips Organization
64 x 8
Voltage
1.8 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
Alienware Area-51 ALX LSI , ASUS Commando Republic of Gamers, CROSSHAIR Republic of Gamers, M2N32 WS Professional, M2N32-SLI Deluxe, M2N32-SLI Premium, M2N-E, M2N-Plus SLI, M2N-VM DH, N4L-VM DH, P5B-MX, P5K SE, P5K WS, P5K64 WS Workstation Series, P5KC AiLifestyle Series, P5K-E/WIFI-AP AiLifestyle Series, P5K-V, P5K-VM AiLifestyle Series, P5SD2-X SE, P5S-MX SE , ASUS P Series P1-P5945G, P2-P5945G, P3-PH4C, P3-PH5X , ASUS T Series T3-P5G965 , ASUS V Series V2-P5V900, V3-P5G965, V3-P5V900 , Biostar TForce4 U 775 , DFI Infinity nF Ultra II-M2, Infinity nF570 SLI-M2/G , ECS 662/1066T-M, 662/1066T-M2, 761GXM-M, 945G-M2, 945G-M3, 945GZT-M, 965PLT-A, AMD480XM-A, AMD690GM-M2, C19-A SLI, C51GM-M, GeForce6100SM-M, K8M890M-M, KA3 MVP, MCP55M-A, NF650iSLIT-A, NFORCE 570 SLIT-A, NFORCE4M-A, NFORCE5M-A, P965T-A, PA1 MVP, PF5 Extreme, PF88, PN2-SLI2+, PX1, RC410L/800-M, RS482-M, RS482M-M, RS485M-M , eVGA nForce 680i LT SLI , Foxconn 45CM, 45GM, 945G7AD-8KS2HV, 945G7MC-KRS2HV, 945G7MD-8EKRS2HV, 945G7MD-8KS2HV, 945G7MD-KS2H, 945G7MD-S2H, 945GC7MC-KRS2H, 945P7AC-8KS2, 945PL7AC-S2, 945PL7AE-8KRS2HV, 946GZ7MA-KRS2H, 975X7AB-2.0-8EKRS2H, A690GM2MA-8KRS2H, G33M, G33M-S, MCP61VM2MA-RS2HV, P35A-S, P9657AB-8EKRS2H, P9657AB-8KS2H, Q9657MC-8KRS2H , Gigabyte GA-MA78G-DS3H , Gigabyte M3 series M3S , Gigabyte ME Series ME-B01, ME-B02 , Intel Desktop Board DG33BU, DG33FB, DP35DP , MSI Axis 945GM , MSI Crystal 945 , MSI Fuzzy 945GM1 , MSI MBOX 945GM3-F, K9N6SGM-V, K9VGM-V , MSI Media Live , MSI Saturn 890 , Sapphire PURE CrossFire 3200 PC-AM2RD580 , Sapphire PURE CrossFire 3200 Advantage PC-AM2RD580ADV , Sapphire PURE Innovation PI-AM2RS690MHD , Shuttle XPC SD30G2, SD30G2B , Shuttle XPC T-Series SS21T, SS31T, T 2100BA, T 2100BB, T 3100BA, T 3100BB , SUPERMICRO C2SBA, C2SBA+, C2SBE , SUPERMICRO SuperServer 5015M-Ni, 5015M-NTRV, 5015M-NTV, 5015M-URV, 5015M-UV , Tyan Toledo i3010W S5197G2NR, S5197G3NR , Tyan Tomcat i945GM S3095G3NR, S3095G3NR-CF
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* brilliant fantastic value
Reviewed by steffan thorning on 11/01/2008
i got this awsome stick of ram when it was about £25 and now it is unbelievably even cheaper at around £15 . ive had no problems whatsoever and performance that is worth four times the value
5* 10/10
Reviewed by Richard Todhunter on 11/06/2007
Works great in Dual Channel mode, no problems so far. Bargain for £20
5* Fantastic value!
Reviewed by Calum on 29/10/2007
I paid £16.45 for this, which is fantastic for 1Gb of high quality RAM.
I can't compare them as I haven't used DDR2 before, so I can't say it's fast, slow, or whatever.
What I can say is that it works just fine, it does what it says and above all it's great value.
Why buy anything else?
5* Superb
Reviewed by Andy on 02/02/2008
Put two of these into an MSI 945 board and installed Vista. The performance rating for the memory is 5.9 :)
5* Works well in dual channel mode
Reviewed by Gerry on 15/03/2007
Put in two of these (in dual channel mode) into a new Gigabyte AM2 board and it works faultlessly. Windows Vista reports a memory benchmark score of 5.8 (against a maximum of 6.0), so that can't be bad! And at under £45 each, having 2gb is now much more affordable.
4* Absolute Bargain
Reviewed by Matt on 31/01/2008
For its price, simply amazing. No problems and cheap as you like. Kingston is a reliable brand.
Only problem I found was its ability to alter timings (for overclocking purposes) was kinda limited, but for those not concerned with such matters, buy it!
Scroll to top
