Click to visit BT.com
BT.com
Wishlist
Kingston ValueRAM HyperX 2GB (2 x 1GB) DDR2 240-Pin 1066MHz / PC8500 Non-ECC CL5
5.0*
Quicklinx: 4S59WS00
Mfr#: KHX8500D2K2/2G
HyperX DDR2 memory, the next-generation evolution of DDR memory technology, is here. Like all Kingston HyperX products, HyperX DDR2 modules were specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. HyperX DDR2 offers faster speeds, lower latencies, higher data bandwidths and lower power consumption.
Kingston HyperX 2GB (1GB 128M x 64-Bit x 2 pcs.) PC2-8500 CL5 240-Pin DIMM Kit
Kingston's KHX8500D2K2/2G is a kit of two 128M x 64-bit 1GB (1024MB) DDR2-1066 CL5 SDRAM (Synchronous DRAM) memory modules, based on sixteen 64M x 8-bit DDR2 FBGA components per module. Total kit capacity is 2GB (2048MB). Each module pair has been tested to run at DDR2- 1066MHz at a latency timing of 5-5-5-15 at 2.2V. The SPD is programmed to JEDEC standard latency 800Mhz timing of 5-5-5-18 at 1.8V. Each 240-pin DIMM uses gold contact fingers and requires +1.8V.
Kingston HyperX - DDR2 - 2 GB : 2 x 1 GB - DIMM 240-pin
RAM memory
2 GB : 2 x 1 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1066 MHz ( PC2-8500 )
Latency Timings
CL5 ( 5-5-5-15 )
Heat sink, dual channel , unbuffered
Voltage
2.2 V
Lead Plating
Gold
Limited lifetime warranty ( Germany, Austria and France - 10 years )
2 GB : 2 x 1 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL5 ( 5-5-5-15 )
Non-ECC
Module Configuration
128 x 64
Chips Organization
64 x 8
Voltage
2.2 V
Lead Plating
Gold
Compatible Slots
2 x memory - DIMM 240-pin
Customer reviews
Write a review for the Kingston ValueRAM HyperX 2GB (2 x 1GB) DDR2 240-Pin 1066MHz / PC8500 Non-ECC CL5 here!
shiny!
Reviewed by Gavin. Review Posted 13/06/2010
very nice! look lovely, perform very well, nicely packed with lifetime warranty. only gripe is the thickness of the heatspreaders. no installation issues, but when place next to one another, there's little room for air to circulate, since they are nearly touching.
now i'm stuck between these and corsair for my next ram upgrade!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
