BT.com
Wishlist
Kingston ValueRAM DDR3L 8GB (2x4GB) DIMM 240-pin 1600 MHz/PC3L-12800 CL11 1.35/1.5V unbuffered
Kingston ValueRAM DDR3L 8GB (2x4GB)...
£54.43
12 in stock
£54.43
Add to wishlist
Delivery
Standard 3-5 working days
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3L - 8 GB: 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB: 2 x 4 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11 (11-11-11)
Temperature monitoring, dual rank, eight banks, On-Die Termination (ODT), dual channel, Low Voltage, unbuffered
Voltage
1.35 / 1.5 V
Lead Plating
Gold
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL11 (11-11-11)
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.35 / 1.5 V
Lead Plating
Gold
Compatible Slots
2 x memory - DIMM 240-pin
Kingston ValueRAM DDR3L 8GB (2x4GB) DIMM 240-pin 1600...
£54.43
Save on this ideal PC Build kit!
Save £10.63
£73.60
Scroll to top
