BT.com
Wishlist
Kingston ValueRAM 8GB 1333MHZ DDR3 ECC CL9 DIMM Module
Kingston ValueRAM 8GB 1333MHZ DDR3...
£69.13
13 in stock
£69.13
Add to wishlist
Delivery
Standard 3-5 working days
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3 - 8 GB - DIMM 240-pin
RAM memory
8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9 (9-9-9)
Temperature monitoring, dual rank, eight banks, On-Die Termination (ODT), unbuffered
Voltage
1.5 V
Lead Plating
Gold
8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL9 (9-9-9)
ECC
Module Configuration
1024 X 72
Chips Organization
X8
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
£69.13
Save on this ideal PC Build kit!
Save £8.29
£88.30
Scroll to top
