BT.com
Wishlist
Kingston ValueRAM 4GB DDR3 1600MHz Non-ECC DIMM 240-pin CL11 SR x8
Kingston ValueRAM 4GB DDR3 1600MHz...
£27.32
More than 50 in stock
£27.32
Add to wishlist
Delivery
Standard 3-5 working days
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3 - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Single rank, unbuffered
Voltage
1.5 V
Lead Plating
Gold
4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
Non-ECC
Module Configuration
512 x 64
Chips Organization
X8
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
Kingston ValueRAM 4GB DDR3 1600MHz Non-ECC DIMM 240-pin...
£27.32
Save on this ideal PC Build kit!
Save £8.40
£46.54
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great ram,cheap reliable
Reviewed by Anonymous on 09/01/2016
When out of the box, it will be alot shorter than most desktop ram, but works just as well. I thought It surprised me when I saw a shorter ram, then I installed and worked great!
Scroll to top
