BT.com
Wishlist
Kingston ValueRAM 4GB (1x4GB) DDR3L 1600MHz Non-ECC DIMM 240-pin CL11
Kingston ValueRAM 4GB (1x4GB) DDR3L...
£28.88
More than 50 in stock
£28.88
Add to wishlist
Delivery
Standard 3-5 working days
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3L - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11 (11-11-11)
Low Voltage, unbuffered
Voltage
1.35 / 1.5 V
Lead Plating
Gold
4 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL11 (11-11-11)
Non-ECC
Module Configuration
512 x 64
Voltage
1.35 / 1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
Kingston ValueRAM 4GB (1x4GB) DDR3L 1600MHz Non-ECC...
£28.88
Save on this ideal PC Build kit!
Save £10.36
£48.43
Scroll to top
