BT.com
Wishlist
Kingston ValueRAM 16GB 1333MHz DDR3 ECC DIMM 240-pin CL9 DR x4 w/TS
Kingston ValueRAM 16GB 1333MHz DDR3...
£124.39
39 in stock
£124.39
Add to wishlist
Delivery
Standard 1-3 working days
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3 - 16 GB - DIMM 240-pin
RAM memory
16 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9
Temperature monitoring, dual rank, registered
Voltage
1.5 V
Lead Plating
Gold
16 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9
ECC
Module Configuration
2048 x 72
Chips Organization
X4
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
Kingston ValueRAM 16GB 1333MHz DDR3 ECC DIMM 240-pin...
£124.39
Save on this ideal PC Build kit!
Save £10.36
£143.94
Scroll to top
