BT.com
Wishlist
Kingston ValueRAM 16GB (2X8GB) 1333MHz DDR3 ECC CL9 K2 Module
Kingston ValueRAM 16GB (2X8GB)...
£106.78
Hurry, only 3 left in stock!
£106.78
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3 - 16 GB: 2 x 8 GB - DIMM 240-pin
RAM memory
16 GB: 2 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9 (9-9-9)
Temperature monitoring, dual rank, eight banks, On-Die Termination (ODT), unbuffered
Voltage
1.5 V
Lead Plating
Gold
16 GB: 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL9 (9-9-9)
ECC
Module Configuration
1024 X 72
Chips Organization
X8
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
2 x memory - DIMM 240-pin
Kingston ValueRAM 16GB (2X8GB) 1333MHz DDR3 ECC CL9 K2...
£106.78
Save on this ideal PC Build kit!
Save £16.94
£132.16
Scroll to top
