BT.com
Wishlist
Kingston ValueRAM 16GB (2 x 8GB) DDR3 1600MHz Non-ECC SODIMM 204-pin CL11
Kingston ValueRAM 16GB (2 x 8GB)...
£103.35
£103.35
Add to wishlist
Delivery
Standard 1-3 working days
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3 - 16 GB: 2 x 8 GB - SO-DIMM 204-pin
RAM memory
16 GB: 2 x 8 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Unbuffered
Voltage
1.5 V
Lead Plating
Gold
16 GB: 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL11
Non-ECC
Unbuffered
Module Configuration
1024 x 64
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
2 x memory - SO-DIMM 204-pin
Kingston ValueRAM 16GB (2 x 8GB) DDR3 1600MHz Non-ECC...
£103.35
Save on this ideal PC Build kit!
Save £8.29
£122.52
Scroll to top
