BT.com
Wishlist
Kingston SSDNow 480GB M.2 SATA 6Gbps Double Side
Delivery
Standard 1-3 working days
Kingston's M.2 SATA G2 SSD is a thin and compact, caseless internal solid state drive that combines high capacity with low power consumption to serve as a reliable caching device or primary storage for the OS and applications. Suitable for popular Small Form Factor (SFF) PCs including Ultrabooks, notebooks, and tablets, the M.2 2280 SATA G2 SSD easily integrates into designs with M.2 connectors and is ideal for system builders and DIY end users. Lighter weight than a cased SSD, the M.2 SATA G2 SSD optimizes performance with advanced garbage collection, wear-leveling and TRIM support to keep performance consistent over the life of the drive. DevSleep, a recent addition to the SATA specification, is an efficient power management option that minimizes power consumption and extends battery life. Firmware-based power loss protection maintains data integrity and ensures data in cache is constantly flushed and hardened to NAND to enable the drive to recover in the event of an unsafe shutdown.
Kingston SSDNow - solid state drive - 480 GB - SATA 6Gb/s
Solid state drive - internal
480 GB
M.2 2280 (double-sided)
SATA 6Gb/s
Data Transfer Rate
600 MBps
TRIM support, Wear Leveling Support, Advanced Garbage Collection, DevSleep mode
22 mm x 80 mm x 3.5 mm
7.98 g
5 years warranty
480 GB
SATA 6Gb/s
22 mm
80 mm
3.5 mm
7.98 g
Performance
Drive Writes Per Day (DWPD)
0.93
SSD Endurance
800 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 520 MBps (write)
4KB Random Read
80000 IOPS
4KB Random Write
80000 IOPS
Maximum 4KB Random Write
85000 IOPS
Maximum 4KB Random Read
90000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - M.2 Card
Compatible Bay
Power Consumption
0.06 Watt (idle) , 1.56 Watt (read) , 3.01 Watt (write)
Limited warranty - 5 years
70 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
Scroll to top
