BT.com
Wishlist
Kingston MobileLite Wireless Reader
Access Your Existing SD & USB Storage Wirelessly! Was £39.99!
Delivery
Standard Due date unavailable
See How The Kingston MobileLite Wireless Reader Can Work For You!
Kingston's MobileLite Wireless reader delivers an unparalleled mobile experience. Because it's not just about being connected, it's about having unlimited access to your favorite videos, music, photos and files from your flash drive and other storage devices - anywhere you go. Store and share more - wirelessly and easily via Wi-Fi - and stream content (for example, three different movies) to three devices at once. Plus, MobileLite Wireless features a battery charger that lets you charge your mobile device to keep you productive.
  • Portable, wireless access to all the content on your Flash drives and SD cards
  • Share your data with three users simultaneously via Wi-Fi
  • Convenient battery charging and backup
  • One-year warranty, free technical support
Access all your data - on the go
MobileLite Wireless works as a portable card reader to give you unlimited access to all of your data, anywhere you are. Use it with your USB Flash drive or SD storage devices to access your videos, music, photos, files and more.
MobileLite Wireless makes it easy to
- Stay connected to the Internet while sharing files and photos with friends for up to 5 hours
- Copy and transfer files between USB Flash drives and SD cards or copy files locally to your mobile device
- Use the MobileLite Wireless app to share photos, files, and movies with up to 3 users simultaneously
- Stay socially connected, even from remote locations. Upload vacation photos from your SD card directly to Facebook and Twitter or to your email
- Free up space by downloading photos from your phone's camera roll to a USB or SD card
Charge your phone anywhere
Use MobileLite Wireless to charge your phone or other device. Stay productive and keep the power flowing without having to plug into a wall outlet.
Read your cards and USB Flash drives
MobileLite Wireless also works as a standard card reader, making it easy to save large files, all of the photos from your vacation and more.
Kingston MobileLite Wireless - network media streaming adapter
Network media streaming adapter
External
Interface (Bus) Type
USB
Ports
USB 2.0
12.48 cm x 5.99 cm x 1.665 cm
98 g
802.11b, 802.11g, 802.11n
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 year warranty
External
USB
Ports
USB 2.0
Wireless
Built-in rechargeable lithium polymer battery
Processor / Memory
Supported Memory Cards
SDXC Memory Card
Expansion Slots
1
1 x USB 2.0 - 4 pin USB Type A
1 x USB
MicroSD adapter
1 x micro-USB to USB cable (external)
Encryption Algorithm
WPA2
Battery - internal
12.48 cm
5.99 cm
1.665 cm
98 g
Limited warranty - 1 year
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.76
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.42
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£22.05
£15.39
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£29.59
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£20.19
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£59.58
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* 21st technology
Reviewed by MICHAEL ALLISON on 11/04/2014
This device came from BT very quickly and the 1st thing I had to do was charge it up using my tablet charger. This took about 2 hours. I then inserted a pre-recorded SD memory card and connected wirelessly to my tablet. This was achieved without any difficulty. I was able to read the contents of the card which included music and photographs on the tablet. I then decided that I wanted to connect the device to the Internet and at first I had a problem but eventually I discovered that I was using the wrong code for my wireless network. After this - all worked perfectly and the device transmitted to my tablet and my laptop. I think this is the most exciting device I have seen recently and would recommend it to all my friends and colleagues. SD storage cards now go up to 64GB.
5* easy to use
Reviewed by Michael Welfare on 17/07/2015
easy to use
Scroll to top
