BT.com
Wishlist
Kingston KTC 8GB 1600MHz Reg ECC Single Rank Memory Module
Delivery
Standard 3-5 working days
Marketing description is not available.
Kingston - DDR3 - 8 GB - DIMM 240-pin
RAM memory
8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Single rank, registered
Voltage
1.5 V
Lead Plating
Gold
Sun Blade X6270, X6270 M2, X6270 M2 Server Module, X6270 M3, X6270 Server Module, X6275, X6275 M2 Server Module, X6275 Server Module; Fire X2270, X2270 ATO base chassis package, X2270 M2, X4170, X4170 M2, X4170 M2 Server, X4170 M3 Server, X4270, X4270 M2, X4270 M3, X4275
8 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Module Configuration
1024 X 72
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
Sun Blade X6270, X6270 M2, X6270 M2 Server Module, X6270 M3, X6270 Server Module, X6275, X6275 M2 Server Module, X6275 Server Module , Sun Fire X2270, X2270 ATO base chassis package, X2270 M2, X4170, X4170 M2, X4170 M2 Server, X4170 M3 Server, X4270, X4270 M2, X4270 M3, X4275
Scroll to top
