BT.com
Wishlist
Kingston KTC 8GB 1600MHz Reg ECC Single Rank Memory Module
Kingston KTC 8GB 1600MHz Reg ECC...
£76.87
£76.87
Add to wishlist
Delivery
Standard Due date unavailable
Marketing description is not available.
Kingston - DDR3 - 8 GB - DIMM 240-pin
RAM memory
8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Single rank, registered
Voltage
1.5 V
Lead Plating
Gold
Cisco MXA UCS C220 M3; UCS B200 M3, B22 M3, B230 M2, B420 M3, B440 M2, C22 M3, C220 M3, C24 M3, C240 M3, C420 M3, Managed C240 M3, Smart Play Bundle B200 M3, Smart Play Bundle B22 M3
8 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Module Configuration
1024 X 72
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
Cisco MXA UCS C220 M3 Rack Server for Cisco Show and Share Enterprise, C220 M3 Rack Server for Cisco Show and Share Workgroup , Cisco UCS B200 M3 Blade Server (Not a standalone SKU), B200 M3 Entry Plus SmartPlay Expansion Pack, B200 M3 Entry Plus SmartPlay Solution, B200 M3 Entry SmartPlay, B200 M3 Entry SmartPlay Expansion Pack, B200 M3 Entry SmartPlay Solution, B200 M3 Entry VDI SmartPlay Expansion Pack, B200 M3 Performance Fusion - IO SmartPlay Expansion Pack, B200 M3 Performance Plus SmartPlay Expansion Pack, B200 M3 Performance SmartPlay Expansion Pack, B200 M3 Performance SmartPlay Solution, B200 M3 TRC System, B200 M3 Value Plus SmartPlay, B200 M3 Value Plus SmartPlay Expansion Pack, B200 M3 Value SmartPlay Expansion Pack, B200 M3 Value SmartPlay Solution, B22 M3 Blade Server (Not a standalone SKU), B22 M3 Entry SmartPlay Expansion Pack, B230 M2 128GB SmartPlay Expansion Pack, B230 M2 256GB SmartPlay Expansion Pack, B230 M2 512GB SmartPlay Expansion Pack, B420 M3 Blade Server (Not a standalone SKU), B420 M3 Value SmartPlay Expansion Pack, B420 M3 Value SmartPlay Solution, C22 M3 High-Density Rack-Mount Server Large Form Factor, C220 M3 Entry 1 Rack Server, C220 M3 Entry 2 Rack Server, C220 M3 High-Density Rack-Mount Server Small Form Factor (Not a standalone SKU), C220 M3 Perform 1 Rack Server, C220 M3 Perform 2 Rack Server, C220 M3 Performance Smart Play, C220 M3 Scale Smart Play, C220 M3 Value 1 Rack Server, C220 M3 Value 2 Rack Server, C24 M3 Entry SmartPlay, C24 M3 High-Density Large Form Factor Rack-Mount Server, C24 M3 High-Density Rack-Mount Server Large Form Factor, C240 M3 Entry 1 Rack Server, C240 M3 Entry 2 Rack Server, C240 M3 Entry SmartPlay, C240 M3 High-Density Rack-Mount Server Small Form Factor (Not a standalone SKU), C240 M3 Perform 1 Rack Server, C240 M3 Perform 2 Rack Server, C240 M3 Scale Smart Play, C240 M3 Value 1 Rack Server, C240 M3 Value 2 Rack Server
Kingston KTC 8GB 1600MHz Reg ECC Single Rank Memory...
£76.87
Save on this ideal PC Build kit!
Save £16.94
£102.25
Scroll to top
