BT.com
Wishlist
Kingston KTC 8GB 1600MHz DDR3L ECC Memory Module
Kingston KTC 8GB 1600MHz DDR3L ECC...
£61.35
1 in stock
£61.35
Add to wishlist
Delivery
Standard 3-5 working days
Marketing description is not available.
Kingston - DDR3L - 8 GB - DIMM 240-pin
RAM memory
8 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin very low profile
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Unbuffered
Voltage
1.35 V
8 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
Speed
Latency Timings
CL11
ECC
Unbuffered
Module Configuration
1 x 72
Voltage
1.35 V
Compatible Slots
Memory - DIMM 240-pin
£61.35
Save on this ideal PC Build kit!
Save £10.36
£80.90
Scroll to top
