BT.com
Wishlist
Kingston KTC 4GB 1600MHz DDR3 ECC Reg Memory Module
Kingston KTC 4GB 1600MHz DDR3 ECC...
£36.27
£36.27
Add to wishlist
Delivery
Standard Due date unavailable
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3 - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Temperature monitoring, single rank, registered
Voltage
1.5 V
Lead Plating
Gold
4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Module Configuration
512 x 72
Chips Organization
X8
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
£36.27
Save on this ideal PC Build kit!
Save £10.76
£55.44
Scroll to top
