BT.com
Wishlist
Kingston KTC 2GB Module
£26.86
5 in stock
£26.86
Add to wishlist
Delivery
Standard 3-5 working days
Kingston is the world's largest independent memory manufacturer. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
This memory is designed for the following systems:
Apple iMac Intel Core 2 Duo 17-inch;
Apple iMac Intel Core 2 Duo 17-inch CD;
Apple iMac Intel Core 2 Duo 20-inch;
Apple iMac Intel Core 2 Duo 24-inch;
Apple iMac Intel Core Duo 17-inch;
Apple iMac Intel Core Duo 20-inch;
Apple MacBook 13-inch;
Apple MacBook Pro 15.4-inch 1.67GHz;
Apple MacBook Pro 15.4-inch 1.83GHz;
Apple MacBook Pro 15.4-inch 2.0GHz/2.16GHz;
Apple MacBook Pro 17-inch 2.16GHz.
Kingston - DDR2 - 2 GB - SO-DIMM 200-pin
RAM memory
2 GB
Memory Type
DDR2 SDRAM - SO-DIMM 200-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
667 MHz (PC2-5300)
Unbuffered
Apple MA939G/A
Limited lifetime warranty (Germany, Austria and France - 10 years)
Apple iMac (Late 2006, Mid 2007); MacBook (Early 2008, Late 2008); MacBook Pro (Early 2008, Late 2006, Late 2007)
2 GB
Upgrade Type
System specific
Apple MA939G/A
DRAM
DDR2 SDRAM
SO-DIMM 200-pin
Speed
667 MHz (PC2-5300)
Non-ECC
Unbuffered
Compatible Slots
1 x memory - SO-DIMM 200-pin
Apple iMac (Late 2006, Mid 2007) , Apple MacBook (Early 2008, Late 2008) , Apple MacBook Pro (Early 2008, Late 2006, Late 2007)
£26.86
Save on this ideal PC Build kit!
Save £8.29
£46.03
Scroll to top
