BT.com
Wishlist
Kingston KTC 2GB DDR2-800 Module SO DIMM
Kingston KTC 2GB DDR2-800 Module SO...
£26.86
5 in stock
£26.86
Add to wishlist
Delivery
Standard 3-5 working days
All Kingston® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
Kingston - DDR2 - 2 GB - SO-DIMM 200-pin
RAM memory
2 GB
Memory Type
DDR2 SDRAM - SO-DIMM 200-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
800 MHz (PC2-6400)
Unbuffered
Toshiba PA3669U-1M2G
Limited lifetime warranty (Germany, Austria and France - 10 years)
Toshiba NB250; NB305; NB500; Portégé A600, M750, M750 3G-129, M800, R600; Qosmio F50, G50; Satellite A300, A350, A500, C650, L350, L450, L500, L500/049, L505, L550, L555, P300, P500, U400, U500, U505; Satellite Pro A300, C650, L300, L450, L500, L550, P300, S300, U400, U500; Tecra A10, M10, R10, S10
2 GB
Upgrade Type
System specific
DRAM
DDR2 SDRAM
SO-DIMM 200-pin
Speed
800 MHz (PC2-6400)
Non-ECC
Unbuffered
Compatible Slots
1 x memory - SO-DIMM 200-pin
Toshiba Portégé A600-138, A600-139, A600-163, A600-SP2801A, M750-W7224V, M800-111, M800-701, R600-12U, R600-SP2803C , Toshiba Qosmio F50-11J, F50-11N, F50-126, F50-127, F50-12M, G50-11R, G50-11S, G50-12I, G50-12L, G50-12X , Toshiba Satellite A300-1KT, A300-1L6, A300-1MZ, A300-1OF, A300-1OG, A300-1PK, A300-1RD, A300-1SM, A300-1SZ, A300-20D, A300-20E, A300-20H, A300-20J, A300-20Q, A300-213, A300-214, A300-21D, A300-234, A300-23H, A300-259, A300-262, A300-27W, A300-27X, A300-29H, A300D-14T, A300D-15E, A300D-17R, A300D-205, A300D-208, A300D-209, A300D-20M, A300D-219, A350-00T, A350-00U, A350-00V, A350-04T, A350-04U, A350-10B, A350-10U, A350-11B, A350-208, A350-20B, A350-211, A350-217, A350-21L, A350-22J, A350D-200, A350D-201, L350-15C, L350-168, L350-200, L350-20J, L350-21F, L350-21M, L350-21P, L350-228, L350-22C, L350-22R, L350-22U, L350-23Q, L350-25T, L500-14F, L500-157, L500-17L, L500D-13U, L500D-14R, L500D-16G, P300-1GO, P300D-20U, U400-13K, U400-17T, U400-17U, U400-18E, U400-20U, U400-20V, U400-218, U400-24K, U400-ST6301, U505-S2002 , Toshiba Satellite Pro A300-108, A300-12H, A300-1BQ, A300-1HL, A300-219, A300-21A, A300-21B, A300-26P, L300-114, L300-20H, L300-24L, L300-24M, L300-29P, L300D-SP5802, L300D-SP5808A, L300-SP5917A, L300-SP6993A, P300-00C, P300-00D, P300-1GJ, S300-120, U400-11O, U400-14A, U400-14C, U400-14F, U400-15, U400-15Z, U400-16A, U400-18S, U400-206, U400-21E, U400-C01, U400-SP2804, U400-ST3301, U400-ST5404 , Toshiba Tecra A10-113, A10-11J, A10-11K, A10-11L, A10-12N, A10-14E, A10-15C, A10-19L, A10-1DX, A10-1E3, A10-1GL, A10-1K2, A10-SP5920C, A10-ST9010, M10-00M, M10-10I, M10-14C, M10-14J, M10-14K, M10-150, M10-15M, M10-16B, M10-16J, M10-16K, M10-16L, M10-17L, M10-18J, M10-198, M10-19W, M10-1CJ, M10-1DH, M10-1E4, M10-1HP, M10-SP5922C, M10-SP5922R, M10-ST9110, M10-ST9117, R10-10P, R10-123, R10-12M, R10-146, R10-147, R10-149, R10-151, S10-00X, S10-125, S10-12G, S10-12P, S10-144, S10-MN6, S10-MN8
£26.86
Save on this ideal PC Build kit!
Save £8.43
£46.08
Scroll to top
