BT.com
Wishlist
Kingston KTC 2GB DDR2-800 Module
£26.86
36 in stock
£26.86
Add to wishlist
Delivery
Standard 3-5 working days
This Kingston product has been developed using industry leading quality processes, ensuring superior quality, performance, and 100% compatibility with the device the module is designed for.
Kingston - DDR2 - 2 GB - SO-DIMM 200-pin
RAM memory
2 GB
Memory Type
DDR2 SDRAM - SO-DIMM 200-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
800 MHz (PC2-6400)
Latency Timings
CL6
Unbuffered
HP KT293AA, HP 451400-001, HP 480861-001, HP GV576AA, HP KT293ET, HP 536428-001, HP 482169-003, HP 482169-002, HP 484381-001, HP 497693-001, HP 484268-002, HP 482169-004, HP 493195-001, HP 482169-001, HP 485033-004, HP KQ436-69006, HP 5189-2822, HP 598858-001, HP 506061-001, HP 506933-001
Limited lifetime warranty (Russia - 10 years)
HP Business Desktop dc7800; Pavilion dv3, dv3570, dv3600, dv3610, dv3630, dv3640, dv3650, dv3660, dv3680, dv3699, dv4, dv5, dv7, s3405, s3421, s3422, s3431, s3432, s3435, s3460, s3488, tx2510, tx2513, tx2517, tx2520, tx2522, tx2530, tx2550, tx2590, tx2622, tx2627; HPE BladeSystem bc2200, bc2800
2 GB
Upgrade Type
System specific
DRAM
DDR2 SDRAM
SO-DIMM 200-pin
Speed
800 MHz (PC2-6400)
Latency Timings
CL6
Non-ECC
Unbuffered
Compatible Slots
1 x memory - SO-DIMM 200-pin
HP Pavilion dv7-1000ef, dv7-1000eg, dv7-1001ef, dv7-1001tx, dv7-1003el, dv7-1003eo, dv7-1003tx, dv7-1004tx, dv7-1005eo, dv7-1006tx, dv7-1007ef, dv7-1007tx, dv7-1008ef, dv7-1008tx, dv7-1009tx, dv7-1010tx, dv7-1011tx, dv7-1012tx, dv7-1013tx, dv7-1014tx, dv7-1015el, dv7-1015tx, dv7-1016tx, dv7-1017tx, dv7-1018tx, dv7-1020ev, dv7-1020tx, dv7-1021tx, dv7-1022tx, dv7-1023em, dv7-1023tx, dv7-1024el, dv7-1024tx, dv7-1025tx, dv7-1027tx, dv7-1029tx, dv7-1030ef, dv7-1030en, dv7-1030tx, dv7-1031tx, dv7-1032tx, dv7-1033tx, dv7-1034tx, dv7-1035ef, dv7-1035em, dv7-1070ei, dv7-1090en, dv7-1090er, dv7-1100ef, dv7-1101ef, dv7-1105eg, dv7-1105em, dv7-1106ef, dv7-1106eg, dv7-1107ea, dv7-1107tx, dv7-1110eo, dv7-1110es, dv7-1112eg, dv7-1114ef, dv7-1115eg, dv7-1115eo, dv7-1115ez, dv7-1116ef, dv7-1117ef, dv7-1118eg, dv7-1118eo, dv7-1119ef, dv7-1120ef, dv7-1120ew, dv7-1122eg, dv7-1123ca, dv7-1125ea, dv7-1125ef, dv7-1125eg, dv7-1125ez, dv7-1127cl, dv7-1127eo, dv7-1128ca, dv7-1128ez, dv7-1130eg, dv7-1130ei, dv7-1130eo, dv7-1130ew, dv7-1133cl, dv7-1134ez, dv7-1134us, dv7-1137eo, dv7-1140eb, dv7-1140ec, dv7-1140ek, dv7-1140es, dv7-1140ew, dv7-1145eb, dv7-1145es, dv7-1150ef, dv7-1150eg, dv7-1150ej, dv7-1150et, dv7-1150ew, dv7-1153ca, dv7-1157cl, dv7-1157es, dv7-1160eb, dv7-1160ek, dv7-1160eo, dv7-1160ep, dv7-1160er, dv7-1160es, dv7-1165eb, dv7-1165er, dv7-1169er, dv7-1170eo, dv7-1170ez, dv7-1173er, dv7-1174ca, dv7-1175eg, dv7-1175er, dv7-1179er, dv7-1180eg, dv7-1180eo, dv7-1183cl, dv7-1185eg, dv7-1190eg, dv7-1190er, dv7-1190es, dv7-1195eg, dv7-1196eg, dv7-1199ec, dv7-1199es, dv7-1199ew, dv7-1199ez, dv7-1245dx, dv7-1270us, dv7-1275dx, dv7-1285dx, s3405.fr, s3421.fr, s3421.nl-m, s3421.sc, s3421.uk, s3422.af, s3422.es, s3422.it, s3422.uk, s3431.uk, s3432.nl, s3435.uk, s3460in, s3488d, tx2513cl, tx2517cl, tx2520ef, tx2522au, tx2550ea, tx2550es, tx2550ew, tx2627cl , HP Compaq Business Desktop dc7800 , HPE BladeSystem bc2200 Blade PC, bc2800 Blade PC
£26.86
Save on this ideal PC Build kit!
Save £10.36
£46.41
Scroll to top
