BT.com
Wishlist
Kingston KTC 16GB DDR3-1333MHz Reg ECC Low Voltage Memory Module
Delivery
Standard Due date unavailable
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR3L - 16 GB - DIMM 240-pin
RAM memory
16 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1333 MHz (PC3-10600)
Quad rank, Low Voltage, registered
Dell PowerEdge C1100, C2100, C6100, C6105, M610, M610x, M710, M710HD, M910, R410, R415, R510, R515, R610, R710, R715, R810, R815, R910, T410, T610, T710; Precision R5500, T5500, T7500
16 GB
Upgrade Type
System specific
DRAM
DDR3L SDRAM
DIMM 240-pin
Speed
ECC
Chips Organization
X8
Compatible Slots
1 x memory - DIMM 240-pin
Dell PowerEdge C1100, C2100, C6100, C6105, M610, M610x, M710, M710HD, M910, R410, R415, R510, R515, R610, R710, R715, R810, R815, R910, T410, T610, T710 , Dell Precision R5500, T5500, T7500
Scroll to top
