BT.com
Wishlist
Kingston KTC 16GB 1600MHz Reg ECC DIMM 240-pin Memory Module
Kingston KTC 16GB 1600MHz Reg ECC...
£149.31
£149.31
Add to wishlist
Delivery
Standard 1-3 working days
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR3 - 16 GB - DIMM 240-pin
RAM memory
16 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Registered
Voltage
1.5 V
Cisco UCS-MR-1X162RY-A
Cisco UCS B200 M3, B420 M3, C200 M2, C210 M2, C220 M3, C240 M3, Mini Smart Play 8 B200, Smart Play 8 B200, Smart Play 8 B420, Smart Play Bundle B200 M3
16 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
ECC
Registered
Voltage
1.5 V
Compatible Slots
1 x memory - DIMM 240-pin
Cisco UCS B200 M3 Blade Expansion, B200 M3 Blade Server, B200 M3 Blade Server (Not a standalone SKU), B200 M3 Blade Server SmartPlay Expansion Pack, B200 M3 Entry Plus SmartPlay Expansion Pack, B200 M3 Entry Plus SmartPlay Solution, B200 M3 Entry SmartPlay, B200 M3 Entry SmartPlay Expansion Pack, B200 M3 Entry SmartPlay Solution, B200 M3 Entry VDI SmartPlay Expansion Pack, B200 M3 Performance Bundle, B200 M3 Performance Fusion - IO SmartPlay Expansion Pack, B200 M3 Performance Plus SmartPlay Expansion Pack, B200 M3 Performance Smart Play, B200 M3 Performance SmartPlay Expansion Pack, B200 M3 Performance SmartPlay Solution, B200 M3 PERFORMANCE-2 SmartPlay Solution, B200 M3 Scale Bundle, B200 M3 TRC System, B200 M3 Value Bundle, B200 M3 Value Plus SmartPlay, B200 M3 Value Plus SmartPlay Expansion Pack, B200 M3 Value Smart Play, B200 M3 Value SmartPlay Expansion Pack, B200 M3 Value SmartPlay Solution, B200 M3 VALUE-2 SmartPlay Solution, B420 M3 Blade Server, B420 M3 Blade Server (Not a standalone SKU), B420 M3 Value SmartPlay Expansion Pack, B420 M3 Value SmartPlay Solution, C200 M2 High-Density Rack-Mount Server, C200 M2 Server for Cisco DMS Applications, C200 M2 Small Form Factor, C210 M2 General-Purpose Rack-Mount Server, C210 M2 General-Purpose Rack-Mount Server with vWAAS, C220 M3 High-Density Rack-Mount Server Small Form Factor, C240 M3 High-Density Rack-Mount Server Small Form Factor, Mini Smart Play 8 B200 M3 Entry, Mini Smart Play 8 B200 M3 Entry Plus, Mini Smart Play 8 B200 M3 Value Plus, Smart Play 8 B200 M3 Performance-2 Expansion Pack, Smart Play 8 B200 M3 Performance-3 Expansion Pack, Smart Play 8 B200 M3 Value 2, Smart Play 8 B420 M3 Value Expansion Pack, Smart Play Bundle B200 M3, Smart Play Bundle B200 M3 Entry, Smart Play Bundle B200 M3 Performance, Smart Play Bundle B200 M3 Value
Scroll to top
