BT.com
Wishlist
Kingston HyperX Savage DDR4 16GB (4x4GB) DIMM 288-pin 2666 MHz/PC4-21300 CL13 1.35V unbuffered
Kingston HyperX Savage DDR4 16GB...
£127.99
11 in stock
£127.99
Add to wishlist
Delivery
Standard 1-3 working days
Marketing description is not available.
HyperX Savage - DDR4 - 16 GB : 4 x 4 GB - DIMM 288-pin
RAM memory
16 GB : 4 x 4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2666 MHz ( PC4-21300 )
Latency Timings
CL13 ( 13-15-15 )
Single rank, black heatsink, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), Black PCB, low profile heat spreader, sixteen banks, asymmetrical heatspreader , unbuffered
Voltage
1.35 V
Lead Plating
Gold
Limited lifetime warranty ( Russia - 10 years )
16 GB : 4 x 4 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.36
Speed
Latency Timings
CL13 ( 13-15-15 )
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.35 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP) - 2400 MHz - 1.35 V - CL13 - 13-14-14 , Intel Extreme Memory Profiles (XMP) - 2666 MHz - 1.35 V - CL13 - 13-15-15
Colour Category
Kingston HyperX Savage DDR4 16GB (4x4GB) DIMM 288-pin...
£127.99
Save on this ideal PC Build kit!
Save £9.16
£147.55
Scroll to top
