BT.com
Wishlist
Kingston HyperX Savage 16GB (2x8GB) 1866MHz DDR3 Non-ECC CL9 DIMM Kit of 2 XMP
Kingston HyperX Savage 16GB (2x8GB)...
£110.77
More than 50 in stock
£110.77
Add to wishlist
Delivery
Standard 1-3 working days
Attack the competition with HyperX® Savage memory. Its unique, asymmetrical red heat spreader is made from high-quality aluminum and has a black PCB and a diamond cut finish to make your game shine and help you stand out in the crowd. The heat spreader dissipates heat so your system stays cool and reliable and its low profile fits under oversized CPU coolers. Built-in, hand-tuned XMP profiles mean that even noobs can overclock their platforms with simple adjustments in BIOS.
HyperX Savage - DDR3 - 16 GB : 2 x 8 GB - DIMM 240-pin
RAM memory
16 GB : 2 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz ( PC3-14900 )
Latency Timings
CL9 ( 9-10-11 )
Dual rank, eight banks, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), dual channel, Black PCB, red heat spreader, low profile heat spreader, asymmetrical heatspreader , unbuffered
Voltage
1.5 V
Lead Plating
Gold
Limited lifetime warranty ( Russia - 10 years )
16 GB : 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.29
Speed
Latency Timings
CL9 ( 9-10-11 )
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.5 V
Lead Plating
Gold
Colour Category
Red
Kingston HyperX Savage 16GB (2x8GB) 1866MHz DDR3...
£110.77
Save on this ideal PC Build kit!
Save £9.16
£130.33
Scroll to top
