Click to visit BT.com
BT.com
Wishlist
Kingston HyperX 4GB (2 x 2GB) DDR3 DIMM 240-Pin 1600Mhz CL9
5.0*
Quicklinx: 5FSRWS00
Mfr#: KHX1600C9AD3K2/4G
Kingston HyperX memory - 4 GB - DIMM 240-pin - DDR3
Kingston's KHX1600C9D3K2/4G is a kit of two 256M x 64-bit 2GB (2048MB) DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Total kit capacity is 4GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.7V to 1.9V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
  • 4GB (2 x 2GB)
  • Technology: DDR3 SDRAM
  • Form Factor: DIMM 240-pin
  • Memory Speed: 1600 MHz ( PC3-12800 )
  • Data Integrity Check: Non-ECC
  • Latency Timings: CL9 ( 9-9-9-27 )
  • Unbuffered
  • Supply Voltage: 1.65 V
  • Lead Plating: Gold
  • Limited lifetime warranty
Kingston HyperX - DDR3 - 4 GB : 2 x 2 GB - DIMM 240-pin
RAM memory
4 GB : 2 x 2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Non-ECC
Speed
Latency Timings
CL9 ( 9-9-9-27 )
Dual channel , unbuffered
Voltage
1.7 - 1.9 V
Lead Plating
Gold
4 GB : 2 x 2 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 ( 9-9-9-27 )
Non-ECC
Module Configuration
256 x 64
Voltage
1.7 - 1.9 V
Lead Plating
Gold
Compatible Slots
2 x memory - DIMM 240-pin
Resources
The following resources are available for the Kingston HyperX 4GB (2 x 2GB) DDR3 DIMM 240-Pin 1600Mhz CL9
Customer reviews
Write a review for the Kingston HyperX 4GB (2 x 2GB) DDR3 DIMM 240-Pin 1600Mhz CL9 here!
Faster than a fast thing thats going really fast
Reviewed by Leon. Review Posted 23/01/2011
I installed 4 of these into my board a couple of days ago. The bios was happy so no tweaking required. Since then everything is instant. Wow load time was reduced from 28 seconds to 4 seconds... Admittedly I only had 2gb of DDR2 800... but still!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
