BT.com
Wishlist
Kingston HyperX 32GB 2400MHz DDR4 CL15 SODIMM Kit
Kingston HyperX 32GB 2400MHz DDR4...
£264.16
10 in stock
£264.16
Add to wishlist
Delivery
Standard 1-3 working days
HyperX HX424S15IBK4/32 is a kit of four 1G x 64-bit (8GB) DDR4-2400 CL15 SDRAM (Synchronous DRAM) 2Rx8, memory modules, based on sixteen 512M x 8-bit DDR4 FBGA components. Total kit capacity is 32GB. Each module supports Intel® Extreme Memory Profiles (Intel® XMP) 2.0. This module has been tested to run at DDR4-2400 at a low latency timing of 15-15-15 at 1.2V.
Kingston HyperX Impact - DDR4 - 32 GB: 4 x 8 GB - SO-DIMM 260-pin
RAM memory
32 GB: 4 x 8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL15 (15-15-15)
Dual rank, On-Die Termination (ODT), sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
32 GB: 4 x 8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
SO-DIMM 260-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL15 (15-15-15)
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.2 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL14 - 14-14-14 , Intel Extreme Memory Profiles (XMP 2.0) - 2400 MHz - 1.2 V - CL15 - 15-15-15
Colour Category
£264.16
Save on this ideal PC Build kit!
Save £10.36
£283.71
Scroll to top
