BT.com
Wishlist
Kingston HyperX 32GB 2133MHz DDR4 CL14 SODIMM Kit
Kingston HyperX 32GB 2133MHz DDR4...
£214.03
Hurry, only 1 left in stock!
£214.03
Add to wishlist
Delivery
Standard 1-3 working days
HyperX HX421S14IBK4/32 is a kit of four 1G x 64-bit (8GB) DDR4-2133 CL14 SDRAM (Synchronous DRAM) 2Rx8, memory modules, based on sixteen 512M x 8-bit DDR4 FBGA components. Total kit capacity is 32GB. Each module kit supports Intel® Extreme Memory Profiles (Intel® XMP) 2.0. This module has been tested to run at DDR4-2133 at a low latency timing of 14-14-14 at 1.2V.
Kingston HyperX Impact - DDR4 - 32 GB : 4 x 8 GB - SO-DIMM 260-pin
RAM memory
32 GB : 4 x 8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz ( PC4-17000 )
Latency Timings
CL14 ( 14-14-14 )
Dual rank, On-Die Termination (ODT), sixteen banks, Intel Extreme Memory Profiles (XMP 2.0) , unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty ( Russia - 10 years )
32 GB : 4 x 8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
SO-DIMM 260-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL14 ( 14-14-14 )
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.2 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL14 - 14-14-14 , Intel Extreme Memory Profiles (XMP 2.0) - 2133 MHz - 1.2 V - CL14 - 14-14-14
Colour Category
£214.03
Save on this ideal PC Build kit!
Save £9.16
£233.59
Scroll to top
