BT.com
Wishlist
Kingston DDR3L 16GB DIMM 240-pin 1333 MHz/PC3-10600 registered ECC
Kingston DDR3L 16GB DIMM 240-pin...
£123.15
£123.15
Add to wishlist
Delivery
Standard Due date unavailable
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR3L - 16 GB - DIMM 240-pin
RAM memory
16 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1333 MHz (PC3-10600)
Low Voltage, registered
IBM 49Y1563
Limited lifetime warranty (Russia - 10 years)
IBM Flex System x440 Compute Node; System x3850 X5; Lenovo Flex System x240 Compute Node; x440 Compute Node; System x3300 M4; x3500 M4; x3530 M4; x3550 M3; x3550 M4; x3630 M4; x3650 M3; x3650 M4; x3690 X5; x3750 M4; x3850 X5; x3950 X5
16 GB
Upgrade Type
System specific
IBM 49Y1563
DRAM
DDR3L SDRAM
DIMM 240-pin
Speed
ECC
Compatible Slots
1 x memory - DIMM 240-pin
IBM Flex System x440 Compute Node 7917 , IBM System x3850 X5 7146, 7191 , Lenovo Flex System x240 Compute Node 8737 , Lenovo Flex System x440 Compute Node 7917 , Lenovo System x3300 M4 7382 , Lenovo System x3500 M4 7383 , Lenovo System x3530 M4 7160 , Lenovo System x3550 M3 7944 , Lenovo System x3550 M4 7914 , Lenovo System x3630 M4 7158 , Lenovo System x3650 M3 7945 , Lenovo System x3650 M4 7915 , Lenovo System x3690 X5 7147, 7148 , Lenovo System x3750 M4 8722 , Lenovo System x3850 X5 7143, 7145 , Lenovo System x3950 X5 7143, 7145
Scroll to top
