BT.com
Wishlist
Kingston DDR3 8GB DIMM 240-pin 1866 MHz/PC3-14900 CL13 1.5 V registered ECC
Kingston DDR3 8GB DIMM 240-pin 1866...
£78.22
£78.22
Add to wishlist
Delivery
Standard Due date unavailable
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR3 - 8 GB - DIMM 240-pin
RAM memory
8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1866 MHz (PC3-14900)
Latency Timings
CL13
Registered
Voltage
1.5 V
Lead Plating
Gold
Dell PowerEdge C6220, M620, R620, R720, R720xd, T620; Precision T3610, T5610, T7610; Precision Fixed Workstation R7610, T7600, T7600 Advanced, T7600 Base, T7600 Essential
8 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL13
ECC
Registered
Module Configuration
1024 X 72
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
Dell PowerEdge C6220, M620, R620, R720, R720xd, T620 , Dell Precision T3610, T5610, T7610 , Dell Precision Fixed Workstation R7610, T7600, T7600 Advanced, T7600 Base, T7600 Essential
Scroll to top
